查看: 8500|回复: 11
今天发个超级长贴,光电行业术语,有兴趣的慢慢看
发表于 2007-12-13 11:35:44 | 显示全部楼层 |阅读模式
光电行业术语1
       光具座 Optical Benches
  光学桌平台 Optical Table Tops
  除震台/防震台 Vibration Isolators
  自动定位装置(含微处理机控制式) Microprocessor-Controlled Automatic Positioning Equipment
  压电定位设备 Piezoelectric Positioning Equipment
  激光定位设备 Laser Positioning Equipment
  直线台定位设备 Linear Stage Positioning Equipment
  回转台定位设备 Rotation Stage Positioning Equipment
  线性致动器 Linear Actuators
  脉冲马达 Pulse Motors
  步进式马达 Stepping Motors
  其他光学机构器材/实验设备 Other Optical Hardwares/Testing Equipment
  电源供应器及放大器 POWER SUPPLIES, AMPLIFIERS
  激发光源用电源供应器 Power Supplies for Pumping Light Source
  半导体激光用电源供应器 Power Supplies for Diode Laser
  电子束用电源供应器 Power Supplies for Electron Beam
  离子束用电源供应器 Power Supplies for Ion Beam
  宽频放大器 Broadband Amplifiers
  锁定放大器 Lock-In Amplifiers
  对数放大器 Logarithmic Amplifiers
  前级放大器 Preamplifier Amplifiers
  其他电源供应器/放大器 Other Power Supplier/Amplifiers
  E03 制造及加工设备/机具 MANUFACTURING AND PROCESSING EQUIPMENT
  预型体制造设备(MCVD法) Preform Rod Manufacturing Equipment(MCVD)
  预型体制造设备(VAD法) Preform Rod Manufacturing Equipment(Vapor Axial Deposition,VAD)
  预型体制造设备(其他) Other Preform Rod Manufacturing Equipment
  预型体研磨加工设备 Preform Rod Polishing Mechanics
  射出成形机 Injection Molding Equipment
  其他成形机 Other Molding Equipment
  光纤引线炉,纺丝设备 Fiber Optic Furnaces, Spinning Equipment
  镀膜设备 Coating Equipment
  光缆制造设备 Fiber Optic Cable Manufacturing Equipment
  光纤端面研磨设备 Fiber Optic Polishing Machines
  光纤融接设备 Fiber Optic Fusion Splice Equipment
  玻璃产生机 Glass Generators
  曲线产生机 Curve Generators
  光学元件研磨加工设备 Optical Device Polishing Machines
  光学元件真空蒸镀设备 Optical Device Vacuum Evaporation Equipment
  单结晶制造设备 Crystal Growing Equipment
  切削加工设备 Cutting Machines
  半导体研磨加工设备 Semiconductor Polishing Machines
  半导体真空蒸镀设备 Semiconductor Vacuum Evaporation Equipment
  光罩制造设备 Mask Making Equipment
  离子植入机 Ion Implantation Equipment
  扩散炉 Diffusion Furnaces
  化学气相沉积法设备(CVD) Chemical Vapor Deposition(CVD) Equipment
  电浆CVD设备 Plasma CVD Equipment
  光CVD设备 Photo CVD Equipment
  MOCVD设备 Metal Organic Chemical Vapor Deposition(MOCVD) Equipment
  MBE设备 Molecular Beam Epitaxial Reactors
  溅镀设备 Sputtering Equipment
  氧化设备 Oxidation Furnaces
  曝光设备 Exposure Sources
  蚀刻设备 Etching Machines
  灰烬设备 Ashing Equipment
  组合用设备 Assembling Equipment
  紫外线硬化设备 Ultraviolet Curing Equipment
  洗净装置 Cleaning Equipment
  配向膜涂布装置 Alignment Coating Equipment
  间隔物散布装置 Spacer Dispersion Equipment
  液晶注入装置 Injection Equipment
  激光退火装置 Laser Annealing Equipment
  TAB实装装置 TAB Equipment
  COG实装装置 COG Equipment
  光纤剥线夹 Fiber Optic Strippers
  光纤分配板 Fiber Optic Distribution Panels
  热交换器 Heat Exchangers
  散热器 Heat Sinks
  真空帮浦 Vacuum Pumps
  防湿保存箱 Moisture-Proofing Storages
  洗净设备 Washing/Cleaning Equipment
  光学元件机具 Cleaning Materials/Equipment for Optics
  无尘室用机具 Clean Room Supplies
  环境试验机 Environment Chambers
  筛选机,机具 Jigs,Tools,and Machines
  委托业务、软体及其他服务 SERVICES
  镀膜加工 Coatings
  激光加工代工中心 Laser Job Shops
  光学设计及技术服务 Optical Design and Engineering Services
  蚀刻服务 Etching Services
  光学材料机械加工 Optical Materials Machining Services
  光学元件订制 Optics Custom Fabrication
  镜头/光学设计顾问 Lens/Optical Design Consultants
  光学设计软体及设备 Optical Design Software and Equipment
  电脑软体 Computer Software
  设备出租 Rental Equipment
  人力服务 Recruitment Services and Executive Search
光电行业术语2
光碟片 OPTICAL DISCS
  CD 音碟片 Compact Discs
  LD 影碟片 Laser Discs
  影音光碟片 Video CDs
  DVD光碟片 Digital Versatile Discs : DVDs
  迷你音碟片 Mini Discs : MDs
  CD-ROM 光碟片 CD-ROMs
  DVD-ROM光碟片 DVD-ROMs
  CD-R 光碟片 CD-Rs
  其他可写仅读型光碟片 Other Recordable Optical Discs
  3.5“ MO 光碟片 3.5” MO Discs
  C07-011 5.25“ MO 光碟片 5.25” MO Discs
  PD 光碟片 PD Discs
  CD-RW 光碟片 CD-RW Discs
  其他可复写型光碟片 Other Rewritable Optical Discs
  光输出入装置 OPTICAL INPUT &OUTPUT DEVICES
  数位相机 Digital Still Camera
  光学印表机 OPTICAL PRINTERS
  彩色激光印表机 Laser Color Printers
  单色激光印表机 Laser Monochrome Printers
  彩色LED印表机 LED Color Printers
  单色LED印表机 LED Monochrome Printers
  其他光学式印表机 Other Optical Printers
  影印机 COPY MACHINES
  彩色激光数位影印机 Laser Digital Color Copy Machines
  单色激光数位影印机 Laser Digital Monochrome Copy Machines
  传真机 FACSIMILES
  热感纸传真机 Termal Paper Facsimiles
  热转写传真机 Thermal Transfer Fax
  喷墨普通纸传真机 Inkjet Plain Paper Facsimiles
  发光二极体传真机 LED Facsimiles
  激光传真机 Laser Facsimiles
  多功能复合事务机 Multi-Function Products (MFPs)
  条码扫描器 BAR CODE SCANNERS
  手持式激光条码扫描器 Hand-Held Laser Bar Code Scanners
  固定式激光条码扫描器 Fixed Laser Bar Code Scanners
  CCD 条码扫描器 CCD Bar Code Scanners
  光笔式条码扫描器 Wand Bar Code Scanners
  其他条码扫描器 Other Bar Code Scanners
  影像扫描器 IMAGE SCANNERS
  平台式影像扫描器 Flat-Bed Color Image Scanners
  馈纸式影像扫描器 Sheet-Fed Color Image Scanners
  手持式影像扫描器 Hand-Held Color Image Scanners
  光学字元阅读机(OCR) Optical Character Recognition Equipment(OCR)
  其他光资讯设备 OTHER OPTICAL INFORMATION EQUIPMENTS
  光学滑鼠 Optical Mice
  电子白板 Detector Array Type Electronic White Boards
  有机感光鼓 Organic Photo Conductor Drum
  C09 医疗用设备 MEDICAL EQUIPMENT
  二氧化碳激光手术刀 CO2 Laser Surgical Knives
  二氧化碳激光医疗系统 CO2 Laser Medical Systems
  YAG激光医疗系统 YAG Laser Medical Systems
  准分子激光医疗系统 Excimer Laser Medical Systems
  激光针(针灸用) Laser Needles for Acupuncture
  激光光凝固设备(Argon,YAG) Laser Coagulators(Ar, YAG)
  光化学治疗设备 Photo Chemical Curing Systems
  激光都卜勒血流计 Laser Doppler Blood Current Velocity Meters
  激光流体细胞仪 Laser Flow Cyto Meters
  内视镜,医疗用光纤镜(Fiber Scope) Endoscopes, Fiber Optic Medical Fiberscopes
  其他医用激光设备 Other Medical Equipments
  激光设备 Laser Equipment
  YAG激光加工机(铭刻用) YAG Laser Processing Equipment for Scribing
  YAG激光加工机(半导体整修用) YAG Laser Processing Equipment for Semiconductor Trimming
  YAG激光加工机(半导体图案处理曝光用) YAG Laser Processing Equipment for Semiconductor Lithorgraphy
  准分子激光加工机(CVD用) Excimer Laser Processing Equipment for Chemical Vapor Deposition(CVD)
  准分子激光(缩小投影曝光设备用) Excimer Laser Processing Equipment for Wafer Stepper
  准分子激光加工机(微机电用) Excimer Laser Procossing Equipment for Micromaching
  其他准分子激光加工机 Other Excimer Laser Processing Equipment
  产业用激光设备 LASER PROCESSING EQUIPMENT
  二氧化碳激光加工机(切割加工用) CO2 Laser Processing Equipment for Removal
  二氧化碳激光加工机(焊接加工用) CO2 Laser Processing Equipment for Joining
  二氧化碳激光加工机(标记用) CO2 Laser Processing Equipment for Marking
  二氧化碳激光加工机(表面处理用) CO2 Laser Processing Equipment for Surface Treatment
  二氧化碳激光加工机(铭刻用) CO2 Laser Processing Equipment for Scribing
  YAG激光加工机(切割加工用) YAG Laser Processing Equipment for Removal
  YAG激光加工机(焊接加工用) YAG Laser Processing Equipment for Joining
  YAG激光加工机(标记用) YAG Laser Processing Equipment for Marking
  YAG激光加工机(表面处理用) YAG Laser Processing Equipment for Surface Treatment
  激光娱乐器材 Laser Entertainment Equipment
  显示装置 DISPLAY PRODUCT
  液晶投影机 LCD Projectors
  液晶监视器 LCD Monitors
  液晶电视 LCD TVs
  电浆电视 PDP TVs
  汽车导引系统 Car Navigation Systems
  发光二极体显示(幕)系统 LED Display Systems
  光纤显示器 Optical Fiber Displays
  头戴式显示器 Head Mounted Displays(HMD)
  抬头显示器 Head-Up Displays(HUD)
  全像显示器 Holographic Displays
  激光显示器 Laser Displays
  印刷制版用激光装备 Laser Equipment for Printing
  光通讯系统 OPTICAL COMMUNICATION SYSTEMS
  长途干线/局间中继光通讯系统 Optical Communication System,Long-haul Terrestrial & Local Interoffice
  用户回路光通讯系统 Optical Communication System, Subscriber Loop
  光区域网路系统 Optical LAN System
  有线电视光传输系统 CATV Optical Transmission System
  光行动通讯系统 Mobile Optical Communication System(Vehicles)
  光视讯传输系统 Video Optical Transmission System
  光空间传输系统 Spatial Optical Transmission System
  其他光通讯系统 Other Optical Communication System
  Solar Cell Application Systems
  Sunlight Transimission Systems
  Remote Sensing Systems
  Environment Monitoring/Measuring Systems
  Other Optoelectronic Systems
  光学机构器材/实验设备 OPTICAL HARDWARES/TESTING EQUIPMENT
光电行业术语3
  标记感测器 Mark Photo Sensors
  色彩标记感测器 Color Mark Photo Sensors
  色彩感测器 Color Photo Sensors
  光学式编码器,角度感测器 Optical Encoders, Angle Sensors
  光遥控器 Optical Remote Control Equipment
  影像感测器式量测设备 Image Sensor Type Measurement Instruments
  显微镜式量测设备 Microscope Type Measurement Instruments
  精密长度干涉仪 Precise Length Interferometers
  光波测距装置 Electronic Distance Meters
  三角测量法距离感测器 Triangulation Distance Meters
  激光调变测距方式距离感测器 Laser Modulation Distance Meters
  脉冲测距方式距离感测器 Pulse Distance Meters
  激光外径测定器 Laser Outer Diameter Measuring Sensors
  激光厚度计 Laser Thickness Gauges
  激光拉伸计 Laser Extension Meter
  红外线厚度计 Infrared Thickness Gauges
  水平仪 Levels
  激光水平仪 Laser Levels
  经纬仪 Theodlites/Transits
  激光经纬仪 Laser Theodlites/Transits
  激光标线设备 Laser Marking-off Equipment
  位置光电感测器 Position Sensors, Pattern Edge Sensors
  半导体位置感测器 Position Sensitive Devices(PSDs)
  激光指示器 Laser Pointers
  激光都卜勒测速计 Laser Doppler Velocimeters
  环形激光流速计,光纤陀螺仪 Ring Laser Velocimeters, Optical Fiber Laser Gyros
  转速仪 Rotational Speed Meters
  激光都卜勒转速仪 Laser Doppler Rotational Speed Meters
  全像方式图样量测设备 Holographic Method Pattern Measurement Equipments
  激光移位计 Laser Displacement Meters
  激光指纹检测器 Laser Fingerprint Detectors
  光学水质污染检测设备 Optical Water Pollution Measurement and Detection Equipment
  光学大气污染检测设备 Optical Air Pollution Measurement and Detection Equipment
  红外线气体浓度感测器 Infrared Gas Density Meters
  光电式烟检知器 Photo Smoke Detectors
  激光粉尘监视器,粒径量测器 Laser Dust Monitors
  距离测定用激光雷达 Rang-finding Lidar Systems
  环境监测用激光雷达 Environment Monitoring Lidar Systems
  激光表面检查设备 Laser Surface Inspection Equipment
  平面度测定系统 Flatness Testers
  斑点图形量测设备 Speckle Method Pattern Measurement Equipment
  云纹图形量测设备 Moire Method Pattern Measurement Equipment
  影像分析仪 Image Analyzers
  激光缺陷检查设备 Laser Defect Inspection Equipment
  红外线辐射温度感测器 Infrared Thermometers
  人体检知感测器,激光保全设备 Laser Security/Surveillance Equipment
  光计数器 Photo Counters
  激光公害检测设备 Laser Pollution Detective Devices
  激光热常数量测设备 Laser Thermal Constants Measurement Equipment
  全像非破坏检查设备 Holographic Nondestructive Testing Equipment
  光纤感测器 FIBER OPTIC SENSORS
  光纤光电开关/感测器 Fiber Optic Photo Switches/ Sensors
  光纤式标记感测器 Fiber Optic Mark Photo Sensors
  光纤式色彩标记感测器 Fiber Optic Color Mark Photo Sensors
  光纤温度感测器 Fiber Optic Temperature Sensors
  光纤压力感测器 Fiber Optic Pressure Sensors
  光纤声波感测器 Fiber Optic Acoustic Sensors
  光纤变形感测器 Fiber Optic Strain Sensors
  光纤振动感测器 Fiber Optic Vibration Sensors
  光纤移位感测器 Fiber Optic Displacement Sensors
  光纤陀螺仪感测器 Fiber Optic Gyro Sensors
  光纤速度感测器 Fiber Optic Velocity Sensors
  光纤磁通量感测器 Fiber Optic Magnetic Flux Sensors
  光纤磁场感测器 Fiber Optic Magnetic Field Sensors
  光纤电流感测器 Fiber Optic Current Sensors
  光纤电场感测器 Fiber Optic Electric Field Sensors
  光纤浓度、成份感测器 Fiber Optic Density,Constituent Sensors
  光纤油膜感测器 Fiber Optic Oil Film Sensors
  光纤液位感测器 Fiber Optic Liquid Surface Level Sensors
  光纤光分布/放射线感测器 Fiber Optic Light Distribution/Radiation Sensors
  光纤显微镜 Fiber Optic Fiberscopes
  光纤光栅应变感测器 Fiber Grating Strain Sensor
  光储存装置 OPTICAL STORAGE PRODUCT
  消费性光碟机 CONSUMER OPTICAL DISC PLAYERS
  激光唱盘 Compact Disc (CD) Players
  激光音响组合 Products Incorporated CD(CD-Radio-Cassette Tape Recorders)
  LD 影碟机 Laser Disc (LD) Players
  影音光碟机 Video CD Players
  DVD DVD 影碟机 Digital Versatile Disc (DVD) Players
  迷你音碟机 Mini Disc (MD) Players
  资讯用仅读型光碟机 READ-ONLY OPTICAL DISC DRI597VES
  CD-ROMCD-ROM光碟机 CD-ROM Drives
  DVD-ROM DVD-ROM 光碟机 DVD-ROM Drives
  资讯用仅写一次型光碟机 RECORDABLE OPTICAL DISC DRIVES
  CD-R CD-R 光碟机 CD-R Drives
  其他仅写一次型光碟机 Other Recordable Optical Disc Drives
  资讯用可覆写型光碟机 REWRITABLE OPTICAL DISC DRIVES
  3.5“ MO 光碟机 3.5” MO Disc Drives
  5.25“ MO 光碟机 5.25” MO Disc Drives
  PD 光碟机 PD Drives
  CD-RW光碟机 CD-RW Drives
  其他可覆写型光碟机 Other Rewritable Optical Disc Drives
  光碟机零组件 DEVICES OF OPTICAL DISC DRIVES
  光学头,光学读取头 Optical Heads , Pick-up Heads
  光学头伺服装置,伺服用IC模组 Optical Head Controllers, Control Ics/Modules
  光学头驱动装置 Optical Head Servomotors
  光碟匣 Optical Disc Cartridges
  主轴马达 Spindle Motor
光电行业术语4
  数据通讯光纤网路设备 OPTICAL DATA COMMUNICATION NETWORK EQUIPMENT (PREMISES)
  光纤分散式资料介面网路设备 FDDI Network Equipment
  非同步传输模式网路设备 ATM Network Equipment
  高速乙太网路设备 Fast Ethernet Network Equipment
  光纤通道 Fiber Channel
  其他用户光数据通讯设备 Other Optical Data Communication Network Equipment (Premises)
  特殊用途光传输设备 OPTICAL TRANSMISSION EQUIPMENT(SPECIAL PURPOSE)
  有线电视光传输设备 Optical Transmission Equipment, CATV
  视讯/闭路监视光传输设备 Optical Transmission Equipment, Video/CCTV
  量测/控制信号光传输设备 Optical Transmission Equipment, Measure/Control
  空间(无线)光传输设备 Optical Transmission Equipment, Spatial (Wireless)
  光放大器 Optical Amplifier
  其他特殊用途光传输设备 Other Optical Transmission Equipment (Special Purpose)
  光测仪器设备 OPTICAL MEASURING EQUIPMENT
  量测用标准光源 Standard/Stabilized Light Sources
  光功率计(热转换型) Thermal Conversion Type Optical Power Meters
  光功率计(光电转换型) Photoelectric Conversion Type Optical Power Meters
  光谱分析仪 Optical Spectrum Analyzers
  光波长计 Optical Wavelength Meters
  光谱幅宽量测器 Spectral Width Measuring Equipment
  光时域反射计(OTDR) Optical Time-Domain Reflectometers(OTDR)
  基频传输特性检测器 Baseband Frequency Characteristics Evaluation Equipment
  波长色散量测器 Wavelength Dispersion Measuring Equipment
  光纤测试设备 Optical Fiber Test Equipment
  激光光束波形量测器 Laser Beam Profile Measuring Equipment
  光纤尺寸量测器 Optical Fiber Sizes Measuring Equipment
  光纤模态参数测试器 Optical Fiber Mode Field Parameters Test Equipment
  光纤强度测试器 Optical Fiber Strength Test Equipment
  其他光纤相关量测设备 Other Optical Fiber Measurement Equipment
  光连接器尺寸量测器 Optical Connector Sizes Measuring Equipment
  光碟测定检查设备(装置用) Optical Disk Drive Inspection Equipment
  光碟测定检查设备(碟片用) Optical Disk Inspection Equipment
  光度计 Photometers
  复光束光度计,复光束量测器 Double Beam Photometers
  测微光度计 Microphotometers
  感光密度计 Densitometers
  光泽度计 Grossmeters
  照度计 Illuminance Meters
  测距仪 Rangefinders
  曝光计 Exposure Meters
  辉度计 Luminance Meters
  比色计 Comparison Colorimeters
  色彩计(分光型) Spectral Colorimeters
  色彩计(光电型) Photoelectric Colorimeters
  积分球 Integrating Spheres
  折射计 Refractometers
  椭圆计 Ellipsometers
  偏振光镜 Polariscopes
  偏振计 Polarimeters
  比较量测器 Comparators
  焦距仪 Focometers
  球径计 Spheremeters
  OTF(光学转换函数)设备 Optical Transfer Function Instrumentation
  MTF分析/量测装置 Modulation Transfer Function(MTF) Analysis/Measurement Equipment
  投影检查器 Profile Projectors
  自动准直仪 Autocollimators
  光弹性机器 Photoelastic Instruments
  其他光(学)量测器 Other Optical Measurement Equipment
  分光镜、干涉仪 SPECTROSCOPES, INTERFEROMETERS
  分光计 Spectrometers
  单色器 Monochromators
  分光镜,干涉分光镜,摄谱仪 Spectroscopes, Interference Spectroscopes,Spectrographs
  分光光度计,分光测光器 Spectrophotometer
  Michelson干涉仪 Michelson Interferometers
  Tywman Green干涉仪 Tywman Green Interferometers
  Mach-Zehnder干涉仪 Mach-Zehnder Interferometers
  Fizeau干涉仪 Fizeau Interferometers
  Fabry-Perot干涉仪 Fabry-Perot Interferometers
  显微镜,望远镜,照像机 MICROSCOPES, TELESCOPES, CAMERAS
  放大镜 Magnifiers
  单接物镜双眼显微镜 Binocular Microscopes
  双眼实体显微镜,立体显微镜 Stereo Microscopes
  金属显微镜 Metallurgical Microscopes
  偏光显微镜 Polarizing Microscopes
  相位差显微镜 Phase-Contrast Microscpoes
  干涉显微镜,微分干涉对比显微镜 Interferences/Differential Interference Contrast Microscopes
  萤光显微镜 Fluorescence Microscopes
  激光显微镜 Laser Microscopes
  量测用显微镜,工具显微镜 Measurement Microscopes
  显微镜光度计 Microscope Photometers
  折射望远镜,Galilean望远镜 Galilean Refracting Telescopes
  反射望远镜 Reflecting Telescopes
  反射折射望远镜 Catadioptric Telescopes
  35mm焦平面自动对焦相机 35mm AF Focal Plane Cameras
  35mm焦平面手动对焦相机 35mm NON-AF Focal Plane Cameras
  35mm镜头快门多焦点相机 35mm Multi Focal Points Lens Shutter Cameras
  35mm镜头快门单焦点相机 35mm Single Focal Point Lens Shutter Cameras
  中,大型照相机 Medium and Large Size Cameras
  VTR摄影机 VTR Cameras
  电视摄影机 TV Cameras
  高画质电视摄影机 High Definition(HDTV) Cameras
  CCTV摄影机 CCTV Cameras
  全像照像机 Holographic Cameras
  眼镜 Eyeglasses
  夜视设备 Night Vision Equipment
  照像机用之日期显示模组 Date module
  照像机用之底片计数器 Film counter
  APS相机 APS Cameras
  光感测器 OPTICAL SENSORS
  光电开关,光电感测器 Photo Switches, Photo Sensors
光电行业术语5
  多成分影像光纤 Fiber Optic Bundles, Non-silica, Imaging
  光导管 Fiber Optic Lightguides
  其他集束光纤 Other Fiber Optic Bundles
  光缆 FIBER OPTIC CABLE
  单模态标准型松包悬空式光缆 Fiber Optic Cable, Single Mode, Standard, Loosely Buffered, Aerial
  单模态标准型松包管路式光缆 Fiber Optic Cable, Single Mode, Standard, Loosely Buffered, Duct
  单模态标准型松包直埋式光缆 Fiber Optic Cable, Single Mode, Standard, Loosely Buffered, Direct Buried
  单模态标准型紧包单心式光缆 Fiber Optic Cable, Single Mode, Standard, Tightly Buffered, Single Fiber
  单模态标准型紧包多心式光缆 Fiber Optic Cable, Single Mode, Standard, Tightly Buffered, Multifiber
  光纤带 Ribbon
  色散位移光缆 Fiber Optic Cable, Dispersion-Shifted
  偏振恒持光缆 Fiber Optic Cable, Polarization - Maintaining
  其他单模态光缆 Other Single Mode Fiber Optic Cable
  多模态石英系(50/125)光缆 Fiber Optic Cable, Multimode, Silica, 50/125
  多模态石英系(62.5/125)光缆 Fiber Optic Cable, Multimode, Silica, 62.5/125
  多模态石英系(100/140)光缆 Fiber Optic Cable, Multimode, Silica, 100/140
  塑胶光缆 Fiber Optic Cable, Plastic
  石英系塑胶包覆光缆 Fiber Optic Cable, Plastic-Clad Silica
  其他多模态光缆 Other Multimode Fiber Optic Cable
  光纤保护用管 Protect Tubes for Fiber Optic Fiber
  光被动元件/光控制元件 OPTICAL PASSIVE DEVICES/CONTROL DEVICES
  单模态ST光纤连接器 Fiber Optic Connectors, Single Mode, ST
  单模态Biconic光纤连接器 Fiber Optic Connectors, Single Mode, Biconic
  单模态FC/PC光纤连接器 Fiber Optic Connectors, Single Mode, FC/PC
  单模态APC光纤连接器 Fiber Optic Connectors, Single Mode, APC
  单模态FDDI光纤连接器 Fiber Optic Connectors, Single Mode, FDDI
  单模态SC光纤连接器 Fiber Optic Connectors, Single Mode, SC
  单模态D4光纤连接器 Fiber Optic Connectors, Single Mode, D4
  单模态光纤连接器插座(ST,FC/PC,SC,Biconic) Fiber Optic Connectors, Single Mode, Adapter(ST,FC/PC,SC,Biconic)
  单模态多心光纤连接器(MT) Fiber Optic Connectors, Single Mode,Multi-Channel/MT
  其他单模态光纤连接器 Other Single Mode Fiber Optic Connectors
  多模态ST光纤连接器 Fiber Optic Connectors, Multimode, ST
  多模态FC/PC相容光纤连接器 Fiber Optic Connectors, Multimode, FC/PC
  多模态SMA光纤连接器 Fiber Optic Connectors, Multimode, SMA
  多模态FDDI光纤连接器 Fiber Optic Connectors, Multimode, FDDI
  多模态SC光纤连接器 Fiber Optic Connectors, Multimode, SC
  多模态D4光纤连接器 Fiber Optic Connectors, Multimode, D4
  多模态光纤连接器插座(ST,SMA,FC/PC) Fiber Optic Connectors, Multimode,Adapter(ST,SMA,FC/PC)
  多模态多心光纤连接器 Fiber Optic Connectors, Multimode, Multi-Channel
  其他多模态光纤连接器 Other Multimode Fiber Optic Connectors
  套筒 Sleeves
  金属箍(套管) Metal Ferrules
  塑胶箍(套管) Plastic Ferrules
  陶瓷箍(套管) Ceramic Ferrules
  插座 Receptacles
  插头 Plugs
  光连接器(含光纤线) Optical Connectors with Fiber
  光纤耦合器(两分支) Optical Couplers, Tap/Splitter
  光纤耦合器(树状分支) Optical Couplers, Tree
  星状光纤耦合器(穿透形) Transmission Type Star Optical Couplers
  星状光纤耦合器(反射形) Reflection Type Star Optical Couplers
  其他光纤耦合器 Other Optical Couplers
  光分波合波器(两波长) Optical Couplers, WDM, Dual-Wavelength
  光分波合波器(多波长) Optical Couplers, WDM, Over Two Wavelength
  其他光分波合波器 Other Optical WDM Couplers
  光衰减器(固定) Fixed Optical Attenuators
  光衰减器(可变) Adjustable Optical Attenuators
  光隔离器(通信用) Optical Isolators for Communication
  光隔离器(非通信用) Optical Isolators for Non-Communication
  光环流器 Optical Circulators
  光开关(机械式) Mechanical Optical Switches
  光开关(非机械式) Non-mechanical Optical Switches
  光纤光栅 Fiber Bragg Grating
  光移相器 Optical Phase Shifters
  光共振器 Optical Resonators
  空间调变元件 Spatial Light Modulators
  光影像转换元件(ITC) Incoherent to Coherent Devices(ITC)
  光截波器,机械式光调变器 Optical Choppers, Mechanical Modulators
  磁光调变器 Maganeto-Optic Modulators
  声光调变器 Acousto-Optic Modulators
  电光调变器 Electro-Optic Modulators
  波导形调变器,行波形调变器 Optical Waveguide,Travelling-wave Modulators
  类比/强度调变器 Analog/Intensity Modulators
  数位调变器 Digital Modulators
  其他调变器 Other Modulators
  5 光弹性调变器 Photoelastic Modulators
  机械式偏折/扫瞄器(Galvanometer方式) Mechanical Optical Deflectors/Scanners(Galvanometer Mirror)
  声光偏折/扫瞄器 Acousto-Optic Optical Deflectors/Scanners
  电光偏折/扫瞄器 Electro-Optic Optical Deflectors/Scanners
  机械式扫瞄器(回转多面镜方式) Mechanical Optical Scanners(Polygonal Mirrors)
  机械式扫瞄器(全像方式) Mechanical Optical Scanners(Holographic)
  光纤跳接线 Fiber Optic Patchcord Pigtail
  光纤终端箱 Fiber Optic Distribution Box
  光纤接续盒 Fiber Optic Closure
  其他光被动元件/控制元件 Other Optical Passive Devices/Control Devices
  积体光元件 INTEGRATED OPTICAL DEVICES
  光IC Optical IC
  OEIC Optoelectronic IC
  其他光电元件 Other Devices
  光通讯设备 OPTICAL COMMUNICATION EQUIPMENT
  电信用光通讯设备 OPTICAL COMMUNICATION EQUIPEMNT(TELECOMMUNICATION)
  同步光纤网路光波传输系统及多工机设备 Lightwave/Transimission System and Multiplexer Equipment (SONET-Based)
  同步光纤网路光数位回路载波机设备 Optical/Digital Loop Carrier Equipment (SONET-Based)
  同步光纤网路数位交换连接系统设备 Digital Cross Connect System Equipment (SONET-based)
  同步数位阶层光波传输系统及多工机设备 Lightwave/Transmission System and Multiplexer Equipment (SDH-Based)
  同步数位阶层光数位回路载波机设备 Optical/Digital Loop Carrier Equipment (SDH-Based)
  同步数位阶层数位交换连接系统设备 Digital Cross Connect System Equipment (SDH-Based)
  光纤网路单体 ONU(Optical Network Unit)
  非同步光通讯设备 Asynchronous Optical Communication Equipment
  其他公众用光通讯设备 Other Optical Communication Equipment (Telecommunication)
光电行业术语6
  自由电子激光 Free Electron Lasers
  激光用元件 LASER COMPONENTS
  Q 开关 Laser Q-Switches
  激光管 Laser Tubes and Bores
  激光棒 Laser Rods
  激光板 Laser Slabs
  气体再生设备,气体填充设备 Gas Recyclers and Gas Handling Equipment
  激光控制设备 Laser Control Equipment
  激光用盒 Laser Cells
  参数振汤器 Parametric Oscillators
  光脉冲产生设备 Optical Pulse Generators
  激光用共振腔 Resonators for Lasers
  磁铁 Magnets
  激光用冷却设备 Cooling Systems for Lasers
  激光护眼镜 Safty Equipment; Goggles Glasses and Films
  激光光吸收体 Safty Equipment; Laser Absorbers
  激光用安全设备 Safty Equipment; Protective Housings
  发光二极体 LIGHT-EMITTING DIODES; LED
  通信用1.55μm发光二极体 1.55μm LEDs for Communication
  通信用1.30μm发光二极体 1.30μm LEDs for Communication
  通信用0.85μm发光二极体 0.85μm LEDs for Communication
  通信用长波长发光二极体模组 Long Wavelength LED Modules for Communication
  通信用短波长发光二极体模组 Short Wavelength LED Modules for Communication
  可见光发光二极体(红色) Visible (Red) LEDs
  可见光发光二极体(黄色) Visible (Yellow,Orange) LEDs
  可见光发光二极体(绿色,多色) Visible (Green,Multi-Color) LEDs
  可见光发光二极体(蓝色) Visible (Blue) LEDs
  红外线二极体(非通信用) Infrared (not for Communication) LEDs
  文数字表示用发光二极体 Alpha-Numeric LEDs
  发光二极体晶圆(通信用) LED Wafers for Communication
  发光二极体晶圆(非通信用) LED Wafers not for Communication
  发光二极体晶片、晶粒(通信用) LED Chips for Communication
  发光二极体晶片、晶粒(非通信用) LED Chips not for Communication
  光源设备 LIGHT SOURCES
  标准光源 Standard Light Sources
  安定化光源 Stabilized Light Sources
  弧光灯 Arc Light Sources
  氪灯 Krypton Light Sources
  卤素灯 Halogen Light Sources
  氙灯 Xenon /Xenon Flashlamps Light Sources
  紫外线光源 Ultraviolet Light Sources
  真空紫外线光源 VUV Light Sources
  红外线光源 Infrared Light Sources
  闪光光源 Stroboscopic Light Sources
  小型光源 Miniature Light Sources
  光纤光源 Fiber Optic Illuminators
  显示器元件 DISPLAY PANEL
  发光二极体显示器 LED Displays
  液晶显示器 Liquid Crystal Display (LCD)
  电浆显示器 Plasma Display Panels(PDP)
  电激发光显示器 Electroluminescence Display (ELD)
  电铬显示器 Electrochromic Display (ECD)
  真空萤光显示器 Vacuum Fluorescent Display (VFD)
  平面阴极射线管 Flat CRTs
  场发射显示器 Field Emitter Display(FED)
  其他平面显示元件 Other Flat Panel Displays
  检光元件及光纤混成元件 DETECTORS & FIBEROPTIC HYBRID DEVICES
  通信用PIN光二极体 PIN Photodiodes for Communication
  通信用崩溃光二极体 Avalanche Photodiodes for Communication
  通信用(长波长)Ge和III-V族检光元件 Long-wavelength Detectors for Communication
  通信用PIN光二极体模组 PIN Photodiode Modules for Communication
  通信用崩溃光二极体模组 Avalanche Photodiode Modules for Communication
  通信用(长波长)Ge和III-V族检光模组 Long-wavelength Decector Modules for Communication
  光二极体(近红外光) Near-infrafed Photodiodes
  光二极体(可见光) Visible Photodiodes
  光二极体(紫外光) Ultraviolet Photodiodes
  光电晶体 Phototransistors
  光电管 Phototubes
  光电子增倍管(PMT) Photomultipliers
  光导电池 Photoconductive Cells
  热电偶检测器 Thermocouple Detectors
  热堆检测器 Thermopile Detectors
  微道板 Microchannel Plates
  热电检测器 Pyroelectroic Detectors
  辐射热测定器 Bolometers
  其他红外线检测器 Infrared Detectors
  摄像管 Camera Tubes
  线型检光元件 One Dimension Detector Arrays
  面型检光元件 Two Dimension Detector Arrays
  光电耦合器 Photo Coupler
  光断续器 Photo Interrupter
  光反射器 Photo Reflector
  光闸流晶体管 Photocyristors
  光感测元件 Photosensing Units
  内藏电路之光感测器 Detectors with Circuit
  民用用太阳电池 Solar Cells for Consumer Use
  产业用太阳电池 Solar Cells for Power & Space Use
  光纤及光缆 FIBER OPTIC FIBERS & CABLE
  光纤 FIBER OPTIC FIBERS
  石英系多模态步阶式折射率型光纤 Fiber Optic Fibers, Silica, Multimode, Step Index
  石英系多模态渐近式折射率型光纤(50/125) Fiber Optic Fibers, Silica, Multimode, Graded Index,50/125
  石英系多模态渐近式折射率型光纤(62.5/125) Fiber Optic Fibers, Silica, Multimode,Graded Index ,62.5/125
  石英系多模态渐近式折射率型光纤(100/140) Fiber Optic Fibers, Silica, Multimode,Graded Index ,100/140
  石英系单模态标准型光纤 Fiber Optic Fibers, Silica, Single Mode,Standard
  色散位移光纤 Fiber Optic Fibers, Dispersion - Shifted
  偏振恒持光纤 Fiber Optic Fibers, Polarization - Maintaining
  其他单模态光纤 Other Single Mode Optic Fibers
  石英系塑胶包覆光纤 Fiber Optic Fibers, Plastic - Clad Silica
  塑胶光纤 Fiber Optic Fibers, Plastic
  石英系影像光纤 Fiber Optic Bundles, Silica, Imaging
光电行业术语7
  光碟机读取头透镜 Pick-up Head Lenses
  APS相机镜头 APS Camera Lenses
  数位相机镜头 Digital Still Camera Lenses
  液晶投影机镜头 Liquid Crystal Projector Lenses
  镜面 MIRROR
  平面镜 Flat Mirrors
  球面凹面镜,球面凸面镜 Spherical Concave and Convex Mirrors
  抛物面镜,椭圆面镜 Off-Axis Paraboloids and Ellipsoids Mirrors
  非球面镜 Aspheric Mirrors
  多面镜 Polygonal Mirrors
  热镜 Hot Mirrors
  冷镜 Cold Mirrors
  玻璃,玻璃/陶瓷面镜 Glass and Glass-Ceramic Mirrors
  双色向面镜 Dichroic Mirror
  金属面镜 Metal Mirrors
  多层面镜 Multilayer Mirrors
  半涂银面镜 Half-Silvered Mirrors
  激光面镜 Laser Mirrors
  天文用面镜 Astronomical Mirrors
  其他面镜 Other Mirrors
  棱镜 PRISM
  Nicol棱镜 Nicol Prisms
  Glan-Thomson棱镜 Glan-Thomson Prisms
  Wollaston棱镜 Wollaston Prisms
  Rochon棱镜 Rochon Prisms
  直角棱镜 Right-Angle; Rectangular Prisms
  五面棱镜 Pentagonal Prisms
  脊角棱镜 Roof Prisms
  双棱镜 Biprisms
  直视棱镜 Direct Vision Prisms
  微小棱镜 Micro Prisms
  其他棱镜 Other Prisms
  滤光镜 FILTER
  尖锐滤光镜 Sharp Cut (off) Filters
  色温变换滤光镜,日光滤光镜 Colour Conversion/Daylight Filters
  干涉滤光镜 Interference Filters
  中性密度滤光镜 Neutral Density Filters
  空间/光学匹配滤光镜 Spatial/Optical Matched Filters
  双色向滤光镜 Dichroic Filters
  偏光滤光镜 Polarizing Filters
  排除频带滤光镜 Rejection Band Filters
  可调式滤光镜 Turnable Filter
  超窄频滤光镜 Ultra Narrowband Filters
  色吸收滤光镜 Absorption Filters
  红外吸收/反射滤光镜 Infrared Absorbing/Reflecting Filters
  红外透过滤光镜 Infrared Transmitting Filters
  紫外吸收滤光镜 Ultraviolet Absorbing Filters
  紫外透过滤光镜 Ultraviolet Transmitting Filters
  针孔滤光镜 Pinhole Filters
  有色玻璃滤光镜 Colored-Glass Filters
  塑胶滤光镜 Plastic Filters
  照像用滤光镜 Photographic Filters
  全像滤光镜 Holographic Filters
  微小干涉滤光镜 Micro Interference Filters
  激光 LASERS
  气体激光 GAS LASERS
  氦氖激光 He-Ne Lasers
  金属蒸气激光 Metal Vapor Lasers
  氩离子激光 Argon Lasers
  氪离子激光 Krypton Lasers
  二氧化碳激光(气流型) CO2 (Gas Flow type) Lasers
  二氧化碳激光(脉冲,TEA型) CO2 (Pulsed,TEA) Lasers
  二氧化碳激光(密封型) CO2 (Sealed tube) Lasers
  二氧化碳激光(波导型) CO2 (Wave guide) Lasers
  一氧化碳激光 CO Lasers
  氦镉激光 He-Cd Lasers
  氮分子激光 Nitrogen Lasers
  准分子激光 Excimer Lasers
  氙分子激光 Xenon Lasers
  固体激光 SOLID STATE LASERS
  红宝石激光 Ruby Lasers
  玻璃激光 Glass Lasers
  Nd:YAG激光(脉冲式) Nd:YAG (Pulsed) Lasers
  Nd:YAG激光(连续式) Nd:YAG Laser (CW) Lasers
  Nd:YAG激光(半导体激光激发) Nd:YAG (LD Pumped) Lasers
  YLF激光 YLF Lasers
  亚历山大激光 Alexanderite Lasers
  铒固体激光 Erbium Lasers
  半导体激光激发式固态激光 Solid State(LD pumped)Laser
  其他固态激光 Others
  染料激光 DYE LASERS
  染料激光(闪光灯激发) Dye (Flash lamp Pumped) Lasers
  染料激光(激光激发) Dye (Laser Pumped) Lasers
  半导体激光 SEMICONDUCTOR LASERS
  半导体激光(1.55μm带) Semiconductor (1.55μm) Lasers
  半导体激光(1.30μm带) Semiconductor (1.30μm) Lasers
  半导体激光(0.85μm带) Semiconductor (0.85μm) Lasers
  半导体激光(0.78μm带) Semiconductor (0.78μm) Lasers
  半导体激光(0.60μm带) Semiconductor (0.60μm) Lasers
  半导体激光(其他波长带) Other Semiconductor Lasers
  半导体激光模组(长波长) Semiconductor (Long Wavelength) Laser Modules
  半导体激光模组(短波长) Semiconductor (Short Wavelength) Laser Modules
  半导体激光模组(可见光) Semiconductor (Visible) Laser Modules
  铁离子中心激光 F-Center Lasers
  化学激光(HF-DF) Chemical (HF-DF) Lasers
  平板激光 Slab Lasers
  远红外线激光 Far-Infrared Lasers
  真空紫外线激光 Vacuum Ultraviolet Lasers
  多色激光 Multi Colour Lasers
  稳频激光 Frequency Stabilized Lasers
光电行业术语8
  光学材料 Optical Materials
  光学玻璃 Optical Glass
  激光玻璃 Laser Glass
  声光玻璃 Acousto-Optic Glass
  红外线玻璃 Infrared Glass
  红外线材料 Infrared Materials
  紫外线材料 Ultraviolet Materials
  石英镜片 Fused Silica Glass
  光学陶瓷 Ceramics
  矽半导体材料 Silicon Semiconductor Materials
  化合物半导体材料 Compound Semiconductor Materials
  光纤材料 Fiber Optic Materials
  光纤预型体 Fiber Optic Preforms
  PLZT晶圆,钛酸锆酸铅晶圆 PLZT Wafers
  环氧树脂 Epoxies
  声光光学晶体 Acousto-Optic Crystals
  双折射/偏光晶体 Birefringent and Polarizing Crystals
  电光光学晶体 Electro-Optic Crystals
  红外线晶体 Infrared Crystals
  激光晶体 (YAG) YAG Laser Crystals
  激光晶体(亚历山大) Alexandrite Laser Crystals
  激光晶体(GGG) GGG Laser Crystals
  激光晶体(GSGG,GSAG) GSGG GSAG Laser Crystals
  激光晶体(YLF) YLF Laser Crystals
  激光晶体(其他) Other Laser Crystals
  非线性光学晶体 Nonlinear Crystals
  有机光学材料 Organic Optical Materials
  萤光放射晶体 Fluorescent Emission Crystals
  结晶育成材料 Crystals Growing Materials
  镀膜材料 Coating Materials
  光罩材料 Photomask Materials
  真空蒸镀化学药品 Vaccum Evaporation Chemicals
  感光剂 Sensitizers
  影像用材料 Materials for Imaging
  热色材料 Thermochromic Materials
  光色材料 Photochromic Materials
  稀土族材料 Rare Earth Materials
  光碟基板,基板材料 Optical Disk Substrate Materials
  光碟记录材料 Optical Disk Data Storage Materials
  加工用其他材料 MATERIALS FOR PROCESSING
  光学用胶合剂/接著剂 Optical Cements and Adhesives
  光学用气体 Gases for Optical Application
  激光用气体 Gases for Lasers
  光学研磨材料(研磨布纸) Optical-Coated Abrasive
  光学研磨材料(砥粒) Optical-Powder or Grin Abrasive
  光学研磨材料(砥石) Optical-Wheel Abrasive
  研磨化合物 Polishing Compounds
  研磨衬垫及布 Polishing Pads and Cloth
  全像底片及感光板 Holographic Films and Plates
  红外线底片及感光板 Infrared Films and Plates
  相片用化学药品 Photographic Chemicals
  折射率液 Refractive Index Liquids
  显微镜浸液 Microscope Immerison Liquids
  显微镜埋置用材料 Microscope Imbedding Media
  激光用染料 Laser Dyes
  冷媒 Coolants
  拭镜纸 Lens Tissue
  显示器用材料 MATERIALS FOR DISPLAY
  液晶 Liquid Crystals
  导电膜玻璃基板 ITO Glass Substrate
  彩色滤光片 Color Filter
  偏光板/相位差板 Polarizer/ Phase Shift Layer
  显示面板用驱动IC Driver IC
  背光源 Backlight
  配向膜 Alignment Film
  间隔物Spacer
  透镜 LENSES
  单透镜 Simple (Single) Lenses
  球透镜 Ball Lenses
  歪像透镜 Anamorphic Lenses
  圆锥透镜 Conical Lenses
  柱状透镜,环形透镜 Cylindrical & Toroidal Lenses
  非球面透镜 Aspheric Lenses
  反射折射透镜 Catadioptric Lenses
  绕射极限透镜 Diffraction-Limited Lenses
  GRIN透镜 GRIN Lenses (Graduated Refractive Index Rod)
  微小透镜阵列 Micro Lens Arrays
  准直透镜 Collimator Lenses
  聚光透镜 Condenser Lenses
  多影像透镜 Multiple Image Lenses
  傅利叶透镜 Fourier Lenses
  菲涅尔透镜 Fresnel Lenses
  替续透镜 Relay Lenses
  大口径透镜(直径150mm以上) Large Aperture Lenses (150mm)
  复合透镜 Complex Lenses
  红外线透镜 Infrared Lenses
  紫外线透镜 Ultraviolet Lenses
  激光透镜 Laser Lenses
  望远镜对物镜 Telescope Objectives Lenses
  显微镜对物镜 Microscope Objectives Lenses
  接目镜 Eyepieces Lenses
  向场透镜 Field Lenses
  望远镜头 Telephoto Lenses
  广角镜头 Wide Angle Lenses
  可变焦伸缩镜头 Variable Focal Length Zoom Lenses
  CCTV镜头 CCTV Lenses
  影印机镜头 Copy Machine Lenses
  传真机镜头 Facsimile Lenses
  条码扫描器镜头 Bar Code Scanner Lenses
  影像扫描器镜头 Image Scanner Lenses
发表于 2007-12-13 11:40:07 | 显示全部楼层
回复 #1 何必有我 的帖子
顶,不错,收藏了
发表于 2007-12-14 08:33:13 | 显示全部楼层
顶一下,辛苦了。
我也收藏
发表于 2007-12-29 15:34:27 | 显示全部楼层
从哪收集的厉害呀
发表于 2008-1-3 17:15:52 | 显示全部楼层
NB!!
发表于 2008-1-25 08:38:01 | 显示全部楼层
谢谢楼主,收藏起来,以后有需要时再查!
发表于 2008-3-12 17:51:11 | 显示全部楼层
不错不错,先记下
发表于 2008-3-12 20:22:38 | 显示全部楼层
发表于 2008-4-1 19:20:18 | 显示全部楼层
ding dingding太帅了
发表于 2008-4-2 08:37:40 | 显示全部楼层
非常感谢,已经收藏了!!!
发表于 2012-7-14 11:42:30 | 显示全部楼层
good  job!
发表于 2012-7-20 14:04:29 | 显示全部楼层
辛苦辛苦,好贴必顶
