查看: 3124|回复: 0
革命性的电光陶瓷光无源器件(超快VOA)
发表于 2008-1-26 22:56:54 | 显示全部楼层 |阅读模式
BATi (Boston Applied Technologies, Inc.)波士顿应用技术公司) 前身是康宁下面的一个分支,在康宁进行全球架构和业务调整时独立成为一家高科技公司。BATi主要是研发电光陶瓷材料,并在此基础上开发出一系列的光无源器件产品,用于光通讯和设备市场。
上海磐华光通讯科技有限公司代理BATi的全系列产品,任何问题或询价请联系:
电话:021-58325141
传真:021-58329412
手机:13706776900
Email: Sales@Pantotek.com
MSN: Wsljl@hotmail.com
电光陶瓷是一种透明的陶瓷材料,具有电光系数大,反应速度快的优点。与传统的铌酸锂(LN)和液晶(LC)相比,具有以下优点:
        电光系数大(比LiNbO3高100倍以上)
        电光速度快(亚微秒级,比液晶快几个数量级)
        在500~7000nm内透过率高
        光损耗小
        全固态
        具有陶瓷特有的坚固性
BATi基于专利技术的电光陶瓷器件开发了如下系列产品:
EclipseTM 可调光衰减器(VOA)系列
BATi的VOA产品具有高速,低插损,小尺寸,和高可靠性的优点,其产品通过所有的Telcordia测试
        1 Variable Optical Attenuator/Polarization Independent Modulator (VOA/PIM):
dual-function high-speed VOA (<1us)
&#61548;        2 Polarization Maintained VOA (PMVOA):
first polarization-preserved high-speed VOA with integrated detector
&#61548;        3 Directional VOA (DVOA):
high-speed VOA with optical isolation in the return path
&#61548;        4 Variable Add/Drop Module (VADM):
ITU grid channel add/drop with high-speed optical power control
&#61548;        5 Shutter VOA:
integrated optical shutter provides complete power shutoff when needed
&#61548;        6 Slope VOA VOAL:
controls light intensity while adjusting wavelength slope
&#61548;        7 Micro VOA (uVOA):
the smallest VOA
&#61548;        8 VOA Array:
high-speed, multi-channel optical power adjustment (4-, 8-, and 16-chanel)
&#61548;        9 Integrated Drive Card for VOA:
compact, space-saving, 4-layer VOA control
&#61548;        10 VOA Driver:
stand-alone high-speed driver for VOA/PIM application
&#61548;        11 Optical Power Regulator/Limiters:
large dynamic range and high-speed optical power control
AcrobatTM偏振控制器件系列
BATi的偏振控制器件具有高速,小尺寸,和高可靠性的优点,其产品全固化,无任何移动部件,在目前市场上尺寸最小。
&#61548;        1 Polarization Controller/Transformer (PC/PT):
converts any input state-of-polarization (SoP) to any output SoP by electronically control of each independent retardation plates
&#61548;        2 Dynamic Polarization Rotator (PRM):
rotates an incoming light beam while preserves its polarization
characteristics
&#61548;        3 Polarization Sensor (PS):
provides the fastest SoP detection and enables high performance polarimeters
&#61548;        4 Polarization Modulators (PM):
provides high-speed polarization modulation on a linearly  polarized input light
&#61548;        5 PC Evaluation Kits:
packaged PC with driver and feed through for lab bench applications
&#61548;        6 PC Driver Card:
compact 4-channel voltage control board
[ 本帖最后由 netfish 于 2008-2-25 15:26 编辑 ]
