查看: 5713|回复: 1
【白光OLED效能再创新高】
发表于 2008-2-24 17:59:32 | 显示全部楼层 |阅读模式
美国科学家利用三层光发光层(3-EML)结构,让白光有机发光二极管(white organic light-emitting diode, WOLED)的发光效率大幅提升。相较于先前发表的各种WOLED,这种3-EML WOLED在照度(luminance)为1000 cd/m2时的最大发光效率为64±3 lm/W,演色系数(CRI)高达81,而典型WOLED的演色系数大多介于75到80之间。
普林斯顿大学的Yiru Sun指出,上述组件除了具有目前最高的发光效率之一,更重要的是也有很好的CRI,因此可以得到高品质的白光。CRI值反应了物体在光源照射下呈现的色 彩真实度。Sun表示,发展高CRI值的光源对室内照明应用非常重要,CRI值大于70就可视为近似阳光的高品质白光。
电致发光的WOLED通常只含有一层或双层发光层,电子与电洞组成的激子(exciton)便是在此形成。当光层中的激子累积时,往往会发生另科 学家头痛的「三重态-三重态消灭」(triplet-triplet annihilation)现象,即两个三重态激子产生交互作用,其中一个会释出能量,掉到基态,导致组件光效率降低。
Sun发现采用3-EML结构,三个发光层分别发出红、蓝及绿光,由于激子的产生分布会在整个发光层中,因此可以降低激子的局部态密度并抑制三重 态消灭效应。再加上选用与RGB三个主发光体(host)能阶匹配的磷光?质,因此获得到最佳的发光效率与演色性。3-EML结构的另一项优点是可以藉由 改变发光层厚度与?杂浓度,来调整色彩强度,产生较高品质的白光。
该研究小组接着将对组件的使用寿命进行测试,因为这是OLED面临的一大议题。孙表示,他们将研究更多能够应用在此三层发光层结构的?质与主发光 体材料,以求获得更高的发光效率及更长的使用寿命。详见Applied Physics Letters 91, 263503 (2007)。
Efficient white OLED emits clearly
High quality light has been produced by a white OLED using a novel three emission layer structure.
A white OLED (WOLED) boasting a higher quantum efficiency, power efficiency and colour rendering index. Princeton University, Yiru Sun
Left to right shows three 3x3 mm WOLEDs in an array running with low to high current density. Three dopants are incorporated for red, green and blue. The white colour CRI remains the same when current density changes.
Image Credit: Yiru Sun
A white OLED (WOLED) boasting a higher quantum efficiency, power efficiency and colour rendering index compared with previous devices has been unveiled. The US team used a three emission layer (EML) structure to obtain a peak power efficiency of 64±3 lm/W at a luminance of 1000 cd/m2 and CRI of 81. Typical CRI values for WOLEDs are between 75-80. (Applied Physics Letters 91 263503)
"The power efficiency we obtained is one of the highest values among WOLEDs reported so far," Yiru Sun, a researcher at Princeton University, told optics.org. "What's more, we have made no compromise in CRI for high power efficiency as we have also achieved a good quality of white colour balance."
The CRI value indicates the ability of a light source to reproduce the colours of an object it illuminates. "It is important to develop light sources with high CRI values particularly for indoor lighting applications," explained Sun. "A CRI value larger than 70 is considered to have a good quality of white light, similar to sunlight."
Until now, electrophosphorescent WOLEDs have been fabricated with only one or two emission layers, in which excitons are formed. The crucial hurdle facing scientists is triplet-triplet annihilation, which can occur at the emission layer from a pileup of excitons. During the process one triplet exciton is destroyed, reducing the efficiency of the device.
Sun found that introducing a 3-EML structure lowered the local density of excitons and reduced the exciton annihilation effect. What's more, she found that combining the 3-EML structure with carefully selected phosphorescent dopants allowed optimum efficiency and colour rendition to be achieved.
Yiru Sun
"The three sections of the EML are for red, blue and green (RGB) emission separately. Excitons are generated in multiple locations across the full width of the EML which reduces triplet-triplet annihilation," explained Sun. "We chose each of the three RGB dopants so as to have favourable energy alignment with the three hosts. By achieving optimum efficiency for all three colours we enhanced the efficiency of the whole device."
The 3-EML structure offers the additional advantage of allowing the colour intensity to be adjusted. "We can produce a balanced white colour by changing the thickness and doping concentration of the RGB emission region," added Sun.
Although lifetimes of the device were not measured, the team recognizes that this is one of the major issues facing OLEDs and plans to address this in the future. "We will investigate more advanced dopant/ host materials that can be incorporated into this structure to achieve higher efficiency and longer lifetime," concluded Sun.
This research was carried out under the supervision of lead researcher Stephen Forrest from the University of Michigan, US.
发表于 2010-1-7 16:40:43 | 显示全部楼层
深圳市材料表面分析检测中心简介
深圳市材料表面分析检测中心(863材料检测),成立于2001年2月,是由深圳市政府投资建立、面向广大中小企业的公共技术服务平台。中心依照国际标准ISO/IEC 17025建立了严格的质量保证体系,具有中国合格评定国家认可委员会(CNAS)实验室认可证书(No. CNAS L2756)和广东省质量技术监督局计量认证(CMA)证书(No. 2009190010B),拥有第三方实验室独立地位和出具公正检测数据的资质。我中心出具的检测报告已得到国际实验室认可合作组织(ILAC)和亚太实验室认可合作组织(APLAC)中62个实验室认可机构的互认。
中心拥有国际先进的材料分析检测仪器和一支专业的技术队伍,可按GB、ASTM、ISO 等各项标准对各种材料的性能、成分、结构、形貌等进行定性、定量检测,具有专业性、权威性、开放性、综合性等特点。尤其在材料成分定量分析、材料成分定性分析、电镀层和涂层综合性能分析、金相分析、材料力学和热学性能分析、材料失效分析、电子电路失效分析等方面,有深厚的技术实力和经验,通过分析测试,进而提供材料解决方案,帮助众多企业解决了生产中的实际问题,是企业有力的技术支持和保障。
中心以 “科学、公正、准确、高效”为方针,秉承“客户至上”的服务宗旨,以详实的咨询、准确的检测、公正的评价竭诚为相关行业的客户提供专业的分析检测服务,并不断丰富服务内容、 完善服务手段、提高服务质量,成为客户信赖的技术合作伙伴。
近期,为应对欧盟日益严格的有害物质管控法规,中心也正建立相关技术支持团队,联合相关机构,为企业客户提供有关管控法律法规的咨询和培训,帮助客户调查生产环节,并有针对性的提供解决方案,为绿色生产保驾护航。
测试项目一览表:
1.材料成分定量分析
成分是材料结构和性能的基础,能定量的分析出材料中各个组分的含量,对材料品质管控、配方研发、MSDS表格制作具有重要意义。
金属成分定量分析        分析合金中指定元素含量;或分析合金中全元素含量,判定合金的牌号;
高分子材料成分定量分析        分析高分子材料中各主要成分和助剂含量;
精细化学品成分定量分析        分析各种精细化学品的配方,例如胶黏剂、清洗剂、助焊剂等;
MSDS表格制作        在定量分析基础上,制作MSDS表格;
2.材料成分定性分析
微量污染物的成分是什么?来自于哪里?材料异常部位的成分有何变化?材料是何材质呢?您不必再为这些品质管控中的问题伤脑筋了。
微量污染物定性分析        鉴定微量污染物的主要成分,但不判定其具体含量,帮助客户寻找污染源;
材料异常部位成分定性分析        测试材料表面起泡、变色、断裂等部位的成分,帮助客户分析其发生变化的可能原因;
材料主成分定性分析        分析材料的主要成分,判定材料的材质和大类,例如判定某种塑胶是否ABS、某种金属是否铝合金;
3.电镀层和涂层综合性能分析
电镀层和涂层的厚度、表面硬度、剥离强度、耐腐蚀性决定了其使用性能,想对您的电镀层或涂层有个基本的评估吗?我们针对电镀层和涂层的综合性能分析,将使您的涂镀层品质更有保障。
涂镀层厚度        分析涂镀层厚度,可选用荧光法或切片法;
涂镀层表面硬度        测试涂镀层表面硬度;
涂镀层剥离强度        评价涂镀层是否容易脱落或不耐摩擦;
涂镀层耐腐蚀性        根据标准用酸或盐雾腐蚀, 评估其耐腐蚀性能;
4.金相分析
金属的使用性能与金属的微观组织——金相,密切相关。
金相分析        分析金属的微观组织,判断其金相形态;
5.材料力学和热学性能分析
用力学和热学分析来判定材料的使用强度。
材料的力学性能        拉伸强度、弯曲强度、断裂伸长率等;
材料的热学性能        TG、DSC、DMA、TMA等;
6.材料失效分析
探寻材料断裂、变质的原因。
材料的断裂失效分析        例如,无论金属或高分子材料,在存放和使用中产生裂纹乃至断裂,其造成失效的原因是复杂的,通过科学的分析方法可以找到原因,以此避免类似问题出现;
材料的变质失效分析        变质可能是材料断裂的一个原因,但变质还包含材料的变色、失去功能、产生沉淀或分相等事故;
7.电子电路失效分析
用电测、透视、切片观察等方法探寻电子电路失效的原因,研究电子电路的短路和短路的原因,分析焊锡的质量和焊接效果。
8.RoHS、REACH项目咨询
提供RoHS、REACH最新法律法规、检测限值、改善方案的咨询和培训。
863材料检测中心附加项目:对外技术咨询、技术培训及合作开发项目,期待与您合作!
联系方式:
  地址:深圳市罗湖区宝安南路3097号洪涛大厦三楼西
  联系人:周小姐,电话:0755-82111003,传真:0755-25466003
   http://www.szsac.com
