查看: 1629|回复: 4
国产 短波长特种器件及高率器件
发表于 2008-3-14 12:48:39 | 显示全部楼层 |阅读模式
我公司从事短波长400~1064nm 范围内 功率可达5~25W 的光隔离器,光衰减器,光开关,光纤准直器,光纤保偏条线。激光到光纤耦合产品!
价格量大从优!
QQ:179000820
发表于 2008-3-14 13:56:09 | 显示全部楼层
广告贴,BS一个……
 楼主| 发表于 2008-3-14 16:27:19 | 显示全部楼层
MEMS Optical 1x2 Switch
MEMS 1X2 SWITCH is one kind of high speed path of light Switch, this MEMS 1X2 SWITCH is micro-electronics which and the micro-mechanism technology designs based on the MEMS, thus causes the path of light through MEMS the channel to have the change to realize the path of light to transform. MEMS 1X2 SWTICH has the high stable performance and the reliability, the reliability was defers to Telcordia the GR1073 reliability inspection standards, already passed  Telcordia the GR1073 examination.
Features        Applications
High reliability
High Operating power (optical)
Low insertion loss
Wavelength range Broad
Switch time swiftness
non-latching        Optical Reconfiguration
Instrumentation
WDM System
OADM System
OXC System
FBG Sensor System
Optical Router
Specifications
Parameter        Value
Wavelength range        1290~1650nm or 1310/1490/1550±50nm
Insertion loss        typ.0.4dB,max 0.6dB
Return loss        ≥55dB
Polarization dependent loss        <0.1dB
Cross talk        Typ.60dB, Max 55dB
Repeatability        ≤0.05dB
Switch time        <0.2ms, max 0.5ms
Power Consumption        350 mA
Operating Voltage        <5 VDC
Operating power (optical)        typ 500mW, max 1500mW
Operation temperature        0~65℃
Storage temperature        -40~80℃
Durability        >1billion
Size (L x W x H)        26 x 9X9mm
Ordering Information
MSW         Switch channel         Latching or Non-Latching        Fiber Type         Fiber Length         Connector
        14=1x4
18=1x8
110=1x10
112=1x12
113=1x13
116=1x16
3232=32X32        N=Non-Latching
L= Latching         S9=SMF 900um
M5=MMF 50/125/900um
M6=MMF 62.5/125/900um
XX=others        1=1.0m
2=2.0m        NE=None
FA=FC/APC
FC=FC/PC
SA=SC/APC
SC=SC/PC
ST=ST/PC
LA=LC/APC
LC=LC/PC
XX=others
 楼主| 发表于 2008-3-17 12:11:16 | 显示全部楼层
 楼主| 发表于 2008-3-17 12:11:53 | 显示全部楼层
0816  2471138  13698129539
