查看: 4557|回复: 4
Codev文件怎么转化成Zemax文件?帮帮小弟
发表于 2008-3-27 23:00:20 | 显示全部楼层 |阅读模式
发表于 2008-4-1 08:53:14 | 显示全部楼层
在ZEMAX資料匣中有個Seq2ZMX子資料匣
其中有個Seq2ZMX.EXE的檔案就是拿來將code V的.seq檔轉成ZEMAX的.ZMX檔的
Utility to convert Code V(TM) sequence files to ZEMAX files
  Syntax:
  SEQ2ZMX  INPUTFILENAME OUTPUTFILENAME LOGFILENAME
  Where
  INPUTFILENAME is the input sequence file name, i.e. LENS.SEQ
  OUTPUTFILENAME is the output ZEMAX file name, i.e. LENS.ZMX
  LOGFILENAME is the optional log file name. Default = seq2zmx.LOG
  File names may include the drive and path.
  Supported Commands:
  Aspheric surface type
  Conic surface type
  Cylindrical surface type
  Grating surface type
  Spherical surface type
  Default dimensions
  Numerical aperture, F/#
  PIM solve
  Radius or curvature, thickness, glass
  Wavelengths, reference wavelength, and weights
  Field angles, object height, and paraxial image height
  Title
  X,Y,Z tilts, decenters, BEN and DAR commands
  Zooms on thickness
  Disclaimer:
  This utility is provided as is without warranty either expressed or implied.
  The utility is intended to convert simple Code V ver. 8.1 sequence files to
  ZEMAX lens files. Not all Code V commands are supported. Complex systems
  may require additional editing within ZEMAX. Unconverted commands
  are stored in the log file. E-mail conversion suggestions to
  support@zemax.com .
 楼主| 发表于 2008-4-2 18:37:59 | 显示全部楼层
非常感谢CaptainLin
发表于 2009-5-27 09:58:24 | 显示全部楼层
请问ZEMAX資料匣在哪里啊??
发表于 2010-2-5 17:28:31 | 显示全部楼层
我也不清楚,看一下学习了
