查看: 3006|回复: 0
提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/DDR3/24bit DSP/PHY等常用IP cores
发表于 2008-5-19 20:34:24 | 显示全部楼层 |阅读模式
-8bit 1T/2T/4T/12T MCU
  8bit RISC CPU
  Turbo 186
  V6502
  V8086
  16bit MCU
  32bit RISC CPU (MIPS/ARC/ARM)
  IBM PowerPC405
  IBM PowerPC440
  IBM PowerPC460
  IBM PowerPCPLB
  Audio Echo Processor
  16/24 audio DSP Core
  16bit audio echo DSP core
  16bit audio DAC (Digital design parts)
- Interface IP:
  Usb1.0 Host/Device/Hub
  Usb1.0 Low speed/Full speed PHY
  Usb2.0 Host/Device/OTG controller
  USB2.0 HS/OTG PHY @180nm/130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)
  USB2.0 mobile nanoPHY @130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)
  Wireless USB controller/wirless usb driver
  PCI/PCI-X
  PCI-Express endpoint/rootmode/swtich brige controller
  PCI-Express PHY @130nm/90nm/65nm (TSMC/SMIC process)
  IEEE1394 Controller
  Ethernet 10/100/1000 Controller
  Ethernet 10G MAC controller & PHY
  IDE controoler
  SATA host/device Controller
  SATA PHY  @130nm/90nm/65nm (TSMC/SMIC process)
  Media Local BUS IP
  SD_MMC host controller IP
  LCD controller
  MemoryStick Host controller
  Smart card reader
  AMBA2.0/3.0 IP
  AMBA Interface IP
  DDR2/DDR3 memory controller
  DDR2/DDR  memory controller
  DDR3/DDR2 SDRAM PHY
  DDR2/DDR2 SDRAM PHY
  Mobile Storage controller (include SDIO/CEVA/MMC host controller)
  SDIO device controller
  WLAN AFE IP
  TSMC PLL
  Arasan Nand Flash controller/SDIO device controller
  CMOS Sensor Interface IP
  SPDIF Interface IP
- JPEG Encoder/Decoder/Codec
  Motion-JPEG
  MPEG2 Decoder
  H264/MPEG4 codec
  H264/MPEG4 decoder
  H264/MPEG4 encoder
  H264/MPEG4 HD codec
  MPEG4 encoder
  2D graphics core
  3D graphics core for PDA & audio
  3D graphics core for wirless products
  TV encoder
另外还提供各种各样得synopsys &  cadence & mentor & magma
等ASIC设计EDA平台(windows & linux & Solaris版本),有需要
可以email联系详细谈。
Email: soft_cores@163.com
