发表于 2008-7-25 10:58:43
显示全部楼层
http://www.brightsolutions.it/index.php?pageId=15
Wedge DPSSL
High Peak Power Diode Pumped Solid State Laser
All solid state design
Patented Polarization-Switching Technology
Less than 1.5 ns pulse duration
Up to 1 MW peak power
Low heat waste,air cooling
WEDGE emits pulses of 1.5 mJ energy at 1064 nm, duration shorter than 1.5 ns and peak powers exceeding 1 MW.
Based on a proprietary electrooptic Q-switching technology,this monolithic laser source features a very high peak power with excellent wall plug efficiency.
The sealed miniaturized laser head is insensitive to vibrations and harsh environments. High output peak power with relatively low Q-switch energy allows efficient nonlinear harmonic or parametric generation as well as interaction with a wide range of materials.
Harmonic options available:
Second harmonic @ 532 nm
Third harmonic @ 355 nm
Two mechanical configurations available:
Single Unit.
Dual Unit. A Resonator Unit is linked to a Pumping Unit via a fiber optic cable and a Q-switch cable.
Both the versions have built-in finned heat exchangers for air cooling.
Applications
Nonlinear spectroscopy
2nd and 3rd harmonic generation
Visible to IR OPO pumping
Material processing
Surface and intra-volume glass marking |
