查看: 1520|回复: 1
符合军标的大功率泵源
发表于 2008-7-29 12:02:33 | 显示全部楼层 |阅读模式
深圳众望达光电有限公司
(泵源都是符合外太空标准,在0度到55度都是不需要制冷)数据如下:
Telcordia Qualification Capability GR-1209-CORE / GR-1221-CORE / GR-468-CORE  Requirements:
TEST METHOD                                      TEST REQUIREMENT                                    CAPABILITY
Damp Heat                                      85°C/85% 500 hours                                         Internal
Temperature Cycling                     -40°C to +85°C                                                         Internal
Thermal Shock                              0°C to 100°C 15 cycles (hermetic)                          Internal
High Temperature Storage                   DRY 85°C 2000 hours                                          lnternal
High Temperature Storage              DAMP (hermetic) 85°C/85%RH 500 hours                  Internal
Low Temperature Storage                   -40°C 2000 hours                                                          Internal
Cyclic Moisture Resistance                     85-95%RH @ 70°C to -40°C                                           Internal
Temp/Humidity Cycling              -40°C to +85°C  20 to 85%RH Operational                          Internal
Water Immersion                              +45°C 168 hours Operational                                          Internal
DWDM Temperature Effect             -40°C to +85°C, 1 Cycle Operational                          Internal
Fiber Flex/twist/side pull            Up to 1 kg with cycling and insertion loss measurement          Internal
Accelerated Aging                            70°C or 85°C  Operational  5000 hours                          Internal
Mechanical                      Variable Frequency Vibration – 20G (2G operational)          External
Mechanical                                              500G 3 Axis Shock                                          External
RGA Analysis                               After specific time points in long term aging                          External
915nm 7W激光器  纤芯:105/125um  NA:0.15或0.22
975nm 6.5W激光器  纤芯:105/125um NA:0.15或0.22
976nm 25W激光器,体积很小(比915nm 7W激光器大二倍) 纤芯是105/125um.
976nm 15W激光器 ,纤芯:100um  NA:0.22 体积很小(比915nm 7W激光器大二倍)
980nm 50W激光器,纤芯:200um
[ 本帖最后由 cherryyang 于 2008-7-29 12:18 编辑 ]
 楼主| 发表于 2008-8-1 14:42:30 | 显示全部楼层
好东西.一起分享
