查看: 2002|回复: 3
哪儿有卖homodyne detector?
发表于 2008-8-25 19:39:48 | 显示全部楼层 |阅读模式
老在论文上看到“homodyne detector”,这东东是要自己做还是哪儿有卖?
发表于 2008-8-26 10:38:46 | 显示全部楼层
homodyne detector
零差检波器(0)零拍检波器(0)零拍检测器(1)
发表于 2008-8-26 10:40:30 | 显示全部楼层
零拍检测器
     In order to detect their interference fringes, holodyne detection scheme is used and the probability distribution for the output of homodyne detector is calculated when the intial states being linear and circular polarization coherent light.
     为检测它们所产生的干涉条纹,本文采用零拍检测方案,计算了初态为线偏振和圆偏振相干光时零拍检测器输出流的几率分布.
 楼主| 发表于 2008-8-26 21:06:26 | 显示全部楼层
回复 3# ruinan 的帖子
我想知道实验中homodyne detector是需要自己做呢,还是有成品可以买到?
