查看: 8280|回复: 13
ASM公司招聘赴新加坡工作R&D工程師
发表于 2008-9-3 15:54:10 | 显示全部楼层 |阅读模式
ASM Pacific Technology Ltd is the world’s largest assembly and packaging equipment supplier for the semiconductor industry.  Listed in Hong Kong since 1989 (ASMPT), ASM Pacific Technology Ltd is 54% owned by ASM International N.V., a NASDAQ listed supplier of wafer processing equipment.  ASM Pacific Technology Ltd. with headquarters in Hong Kong has operations in Shenzhen, China, Singapore and Malaysia.  We are a leading supplier of a full line of assembly and packaging equipment and process solutions for the semiconductor, photonics and optoelectronics industries. Our financial strength and R&D resources allow us to provide customers with total solutions, process innovation, package development and factory automation.  Further details can be found at http://www.asmpacific.com/
For details of company profile and its products, please visit our website: www.asmpacific.com
Interested applicants may send in their resumes to humanresource@asmpt.com, stj-adm@asmpt.com with indication of position interested and source of website where positions are posted.  We regret that only shortlisted candidates will be notified.
Location of all positions is in Singapore.
CAE Engineers (Working in Singapore)
You will be involved in static and dynamic strength/stiffness analysis of semiconductor packaging equipments using computer-aided engineering software.
Requirements:
Masters/PhD Degree in Mechanical engineering
Good understanding in stress/vibration analysis with finite element technique
Machine design skills and experimental skills are a plus
Control Engineer (Working in Singapore)
You will be responsible for the design, development and sustaining of high performance motion control system. This will require you to be strong in control theory and its application as well as familiar with other disciplines of Mechatronics.
Requirements:
• Masters or PhD Degree in Electrical/Mechanical/ Mechatronics Engineering, specializing in Control
• Proficient in MATLAB ‘C’, real time system, sensor, change motor driver systems
• Analytical, hands-on problem solver and creative
Computer Vision Engineer (Working in Singapore)
You will be responsible for conducting research in computer vision technology; as well as developing advanced vision algorithms and applications for machine automation and visual inspection.
Requirements:
• PHD, Masters or Degree in Electronics Engineering/ Computer Science or a relevant discipline with strong technical background in the field of computer vision and image analysis
• Knowledge of image processing C or C++
Electronic Engineers (Working in Singapore)
You will be responsible for developing software for automation and control applications, including advance algorithm to control machines. You will also test and debug the software and provide technical support at customers’ sites.
Requirements:
• BA/BS/MSC Degree in Electronics/Electrical/Computer Science/Physics
• Good working knowledge of C/C++ and OOP
• Experience in control/automation software, system programming and software testing is a plus
Firmware Engineers (Working in Singapore)
You will design, develop, deploy and sustain firmware for hard real-time embedded control applications. You are expected to provide technical expertise and solutions to production and field for the deployment of controllers.
Requirements:
• Masters/Degree in Computer/Electrical & Electronics/Control Engineering
• Knowledge of the application of real-time operating system, software methodology,
  microprocessor architecture, control strategy and programming languages such as
  C/C++ and Assembly
Mechanical Engineer <Post A> (Working in Singapore)
You will be involved in conceptional mechanical design in the area of semiconductor equipment, including providing pneumatic circuit and optical design support.
Requirements:
&#8226;        Masters Degree in Mechanical Engineering
&#8226;        Familiar with ProE or Solid Edge/Work and MS Office
&#8226;        Good understanding of material and fundamental mechanism with basic knowledge of fabrication process
&#8226;        Basic CAE experience is a plus
&#8226;        Passion for mechanical design and R&D
&#8226;        Able to identify problems and meet targets
Mechanical Engineers <POST B> (Working in Singapore)
You will perform automatic semiconductor assembly equipment design as well as material handling and tooling design. You will also be involved in continuous improvement activities and field trips with a focus in mechanical design.
Requirements:
&#8226; Degree in Mechanical/Production Engineering
&#8226; Proficiency in SolidEdge, Pro-E and Autocad is a must
&#8226; Willing to travel
Mechanical Engineers <POST C> (Working in Singapore)
You will be responsible for mechanical design and development of automated mechanism and high speed/acceleration precision mechanism. You will conduct vibration studies, CAE analysis and improvement on mechanical structures or high speed/acceleration motion mechanisms.
Requirements:
&#8226; Degree or Higher in Mechanical Engineering
&#8226; Proficient in SolidEdge, Autocad and CAE
Material Engineer (Working in Singapore)
You will perform failure analysis and material studies on semiconductor assembly process and equipment.
Requirements:
&#8226;        Good Degree in Material Science
&#8226;        Familiar with the operation of analytical equipment (eg. FESEM, CSAM)
Senior / Process Engineers (Working in Singapore)
You will provide process support for the Encapsulation Solutions Group; as well as providing solutions for advance encapsulation of semiconductor, mold design improvement; encapsulation technology development and new material evaluation.
Requirements:
&#8226; Good Graduate Degree (Master and PhD) in Chemistry (all fields), Physics, Materials Science or Engineering, Chemical Engineering, Engineering (Areas of Fluid Mechanics, Heat Transfer or Semiconductor)
Senior/ Optical Engineers (Working in Singapore)
You will be responsible for research and development in optical and lighting system for machine automation using area cameras and line scan cameras and optical instrumentation for high precision metrology.
Requirements:
&#8226;        Degree or high degree holder in optical engineering or related field
&#8226;        Experience in precision optical design or laser optical design
&#8226;        Familiar with using Zmax in system design and optical flow simulation
&#8226;        Responsible to design optic for advanced 3D inspection machine
說明:
1.        以上职位录用后在本集团新加坡公司R&D工作, 公司负责申办当地居留权。
2.        請將簡歷同時投遞至humanresource@asmpt.com, stj-adm@asmpt.com這兩個郵箱。
3.        投遞簡歷時請注明獲得招聘廣告信息的渠道。
发表于 2008-9-4 09:58:16 | 显示全部楼层
有几个问题想了解一下:
(1)以上职位如何面试?
(2)Senior/ Optical Engineers大概的工资水平是多少?
(3)在新加坡,除了工资以外,一般都有哪些福利?
(4)个人所得税如何?
希望能给我说 一下,以便能大概了解一下那边的情况,谢谢
发表于 2008-9-4 18:53:50 | 显示全部楼层
原帖由 stevenwu 于 2008-9-4 09:58 发表
有几个问题想了解一下:
(1)以上职位如何面试?
(4)个人所得税如何?
希望能给我说 一下,以便 ...
同问
发表于 2008-9-4 21:13:35 | 显示全部楼层
同问 同问。。。
原帖由 kisfire 于 2008-9-4 18:53 发表
同问
同问同问。
发表于 2008-9-5 08:46:14 | 显示全部楼层
没有下文?
发表于 2008-9-6 13:38:50 | 显示全部楼层
phd哦,.....................
 楼主| 发表于 2008-9-30 09:26:17 | 显示全部楼层
回復stevenwu先生問題
抱歉,現在才回答你的問題, 以後請直發電郵給我, 這樣當天就會回復你的.
(1)以上职位如何面试?(ASM在深圳沙頭角有製造基地, 到沙頭角廠通過公司VC與新加坡面試)
(2)Senior/ Optical Engineers大概的工资水平是多少?(在新加坡政府是有規定的, 主要是取決於學歷, 通常約2000-4000新幣, 以後每年都加薪的)
(3)在新加坡,除了工资以外,一般都有哪些福利?(我們是大公司, 可以申請當地居留權, 其他具體的福利都根據新加歧政府規定來的)
(4)个人所得税如何?(按政府規定來的)
另外現在收到簡歷基本上90%都是應屆畢業生, 急需有1-2年工作經驗的加入.
 楼主| 发表于 2008-11-6 08:54:24 | 显示全部楼层
发表于 2008-11-6 11:47:29 | 显示全部楼层
待遇好象没有竞争力,不知道公司的发展空间如何
发表于 2008-11-18 12:38:31 | 显示全部楼层
我有2年半、五六个光机电一体化项目的设计经验。包括零件设计和产品总体设计。熟悉光机装调,熟悉光电系统设计流程,英语水平一般。
产品包括激光测距机、稳像伺服系统、多传感器光电综合体、简易火控、重载超精密齿轮减速器。
有希望不?我发邮件到你信箱了,也发短消息给你了。
发表于 2008-11-19 09:53:50 | 显示全部楼层
2000-4000新币的工资是一般般,大概人民币10000-20000(根据1:5的比例),不过新加坡消费水平不高,生活压力不是很大,有机会还是可以出去看看的。
 楼主| 发表于 2009-7-10 14:17:34 | 显示全部楼层
金融危機過後繼續招聘赴新加坡工作R&D工程師
For details of company profile and its products, please visit our website: http://www.asmpacific.com/asmpt/index.htm
Interested applicants may send in their resumes to humanresource@asmpt.com, with indication of position interested and source of website where positions are posted.  We regret that only shortlisted candidates will be notified.
Location of positions is in Singapore.
Computer Vision Engineers
You will be responsible for conducting research in computer vision technology; as well as developing advanced vision algorithms and applications for machine automation and visual inspection in fast growing semiconductor field/ new energy field.
Requirements:
&#8226; PHD, Masters or Degree in Electronics Engineering/ Computer Science or a relevant discipline with strong technical background in the field of computer vision and image analysis
&#8226; Knowledge of image processing C or C++
Optical Engineer
Requirements:
&#8226;    Master or Degree in optical engineering or related field
