查看: 3222|回复: 10
C-MOUNT封装技术求教
发表于 2008-9-7 14:03:18 | 显示全部楼层 |阅读模式
有哪位同仁哟有这方面的资料
发表于 2008-9-7 19:17:57 | 显示全部楼层
The C-mount is an open package suitable for devices with up to 5W output power with suitable heatsinking. This package is typically used by OEMs who wish to take advantage of the package's small size and the ability to place objects such as lens very close to the laser facet. The disadvantage of this package is that the diode is exposed and therefore subject to mechanical damage. As a result Intense does not warrant open packages.
发表于 2008-9-7 21:53:36 | 显示全部楼层
不知道你要的参数是指哪部分,大片工艺的还是后道封装的或者老化测试的。
我也在做这方面的工作,可以交流一下。
发表于 2008-9-8 09:51:42 | 显示全部楼层
我也正在做这方面的工作,希望互相交流一下!
 楼主| 发表于 2008-9-8 14:20:17 | 显示全部楼层
谢谢你们!但不知道楼上的我们怎么交流啊!我的QQ是285525626
发表于 2008-9-8 14:51:48 | 显示全部楼层
加我QQ吧,我现货C-mount 0.5-3W LD 808出售呀
 楼主| 发表于 2008-9-8 15:48:22 | 显示全部楼层
我是要这方面的资料啊!不是买LD
发表于 2008-9-10 19:58:05 | 显示全部楼层
您好
原帖由 kaka 于 2008-9-8 14:51 发表
我想问问,您有TO封装980的单管没?急需出光功率1W的管子
发表于 2009-1-22 17:24:21 | 显示全部楼层
JOLD-8-BAS-1E
passively cooled single emitter on substrate
optical output power: 8 W cw
wavelengths: 808 nm
JOLD-8-BA-1E / JOLD-7-BAF-1E
passively cooled single emitter on heat sink with or without collimation
optical output power: up to 8 W cw
wavelengths: 808 nm
JOLD-x-CPNN-1L / JOLD-x-QPNN-1L
passively cooled diode laser on CS-mount
optical output power: up to 100 W cw / 100 W qcw
wavelengths: 808 nm – 976 nm
JOLD-x-CPxN-1L / JOLD-x-QPFN-1L
passively cooled diode laser on CS-mount with fast axis and slow axis collimation or fast axis collimation
optical output power: up to 90 W cw / 90 W qcw
wavelengths: 808 nm - 976 nm
JOLD-x-QPNN-1L / JOLD-x-QPFN-1L
passively cooled diode laser on CS-mount without any collimation or with fast axis collimation
optical output power: up to 300 W qcw
wavelengths: 808 nm
passively cooled diode laser with fast axis and slow axis collimation or fast axis collimation
passively cooled diode laser without any collimation or with fast axis collimation
wavelengths: 808 nm
JOLD-x-CANN-1L / JOLD-100-QANN-1L
actively cooled diode laser
optical output power: up to 80 W cw / 100 W qcw
wavelengths: 807 nm – 976 nm
Download data sheet - high power
Download data sheet - standard power
Safety and handling instructions
Contact us
发表于 2009-2-11 12:45:56 | 显示全部楼层
6# kaka
报价价吧
HLASER·126。COM
发表于 2009-3-28 17:15:22 | 显示全部楼层
我在做这个,可以交流
