2008-11-11 16:35:41 | 显示全部楼层 | 阅读模式
含棱镜,透镜,以及塑料件
z.ye@163.com
1499查看4回复
2008-11-12 08:40:29
指纹光学系统找我们啊
2008-11-14 13:38:00
固态光学指纹传感器
MITSUMI
Solid Optical Fingerprint Sensor
SEF-A1F1
OUTLINE
An optical sweep-type compact fingerprint
sensor. Eliminates the shortcomings of
conventional optical fingerprint sensors, which
are large and heavy due to use of lenses and
prisms. The interdigital scattered light method
realizes stable, high-accuracy detection at lowcost
with a major reduction in size and weight.
Increased resistance to static and shock make
this technology ideal for inclusion with a variety
of devices.
FEATURES
1. Small size and light weight achieved by molding optical components as one piece.
2. The semiconductor is not exposed, giving excellent durability.
3. Waterproofing improved through use of a flange.
4. The finger scattered light method allows use on wet fingers.
5. The light filter allows use on dry fingers.
6. A signal processing LSI can be provided (supports SPI and parallel I/F).
USES
1. PC units, portable information devices, network terminals
2. IC card readers
3. Security devices
MITSUMI
DIMENSIONS
Finger Sweep Center
49±1
8.2±1
PIN No.
FPC
Mold
Image Guide
PWB
LED-Assy
1 13
MITSUMI
SEF-A1F1
SPECIFICATIONS
Item Specification
Fingerprint detection method Sweep-type interdigital scattered light method
Structure Single-unit mold including light-source LEDs
Pixels 600dpi-256 pixels/line
Sweep speed 10cm/s
Temperature range Storage: -20 to +80°C, Operation:-5 to +70°C
Electrostatic discharge resistance 20kV
Power source voltage 5.0±0.5V
Consumption current 35mA typ.
Dimensions 18.2 (W) 4.8 (D) 2.8 (H) mm (not including flange)
Unit: mm
*Specifications may be changed for the purpose of improvement and upgrading.
如有任何问题,请回复。
MSN: henryf1019@hotmail.com
2009-2-25 10:18:59
我们公司做的是日本大金的,主要用在眼镜和照相机镜头上,如果有需要请联系1391745330刘燕峰
2009-3-5 11:18:44
这是大金抗指纹剂的资料,请参阅,如有需要请联系13917453370
OPTOOL-DSX的特性
OPTOOL-DSX是透明無色、無味的液體。
用OPTOOL DSX處理過的表面擁有以下主要特性
1、超薄膜塗層,DSX防污層約10nm
2、不損傷底層的表面硬度及光學特性等。
3、防污性極佳優良的光滑性
各種污垢(例如指紋)難以附著,同時具有優良的擦拭性。即使用面紙等擦拭污垢,表面也不留痕跡。
表面特性的例子
下表顯示的是室溫下塗刷在玻璃基板上表面特性的例子
測量項目單位          OPTOOL-DSX   既有的氟處理劑     未處理的玻璃基板
水的接觸角°                   112                      110                            <10
臨界表面張力mN/m          12                        14                                —
十六烷的下落角°               3                         24                                —
膠帶的剝離強度注1) N    0.93                     2.35                             3.62
指紋的附著性            ○                           △                      ╳
指紋的擦拭性            ◎                          △                                ╳
凍冰力注2) kPa             344                      768                               774
耐候性注3) °                 110                       107                                —
耐損耗性注4) °              107                        37                                 —
摩擦係數注5)                0.13                     0.34                                0.57
用途
適合於使玻璃、金屬、陶瓷等材質具有防水防油性、防污性、
防止指紋附著、表面光滑等功能運用上。
●液晶顯示部分的表面防污
(例)數位攝影機、數位相機、汽車導航系統、
行動電話、PDA等
●平面CRT表面的防污
●光學鏡頭表面的防污
(例)眼鏡鏡片、相機鏡頭、各種測量儀器的透鏡等
●OA機器部件表面的防污
(例)影印機的接觸玻璃部分等
