查看: 1978|回复: 6
激光器封装求教?
发表于 2008-11-26 12:45:26 | 显示全部楼层 |阅读模式
我们是做C-count封装的,单管的,“条宽”决定了什么?功率?发散角?还是什么啊
 楼主| 发表于 2009-1-8 21:21:06 | 显示全部楼层
为什么没人顶啊难道没人知道啊!哎悲哀啊
 楼主| 发表于 2009-1-8 21:53:34 | 显示全部楼层
竟然没人顶啊 太出乎我的意料了高手哪里去了?
发表于 2009-1-14 11:41:04 | 显示全部楼层
条宽是指单管尺寸,不同厂家发光面积又不同,一般大功率的从100um至200um不等;功率就是激光器的出光功率;发散角是指快轴和慢轴的光束角度,一般约是<36&ordm; ⊥ <10&ordm; //
发表于 2009-1-14 16:24:22 | 显示全部楼层
呵呵不好意思不太了解。。
发表于 2009-1-22 17:13:28 | 显示全部楼层
JOLD-8-BAS-1E
passively cooled single emitter on substrate
optical output power: 8 W cw
wavelengths: 808 nm
JOLD-8-BA-1E / JOLD-7-BAF-1E
passively cooled single emitter on heat sink with or without collimation
optical output power: up to 8 W cw
wavelengths: 808 nm
JOLD-x-CPNN-1L / JOLD-x-QPNN-1L
passively cooled diode laser on CS-mount
optical output power: up to 100 W cw / 100 W qcw
wavelengths: 808 nm – 976 nm
JOLD-x-CPxN-1L / JOLD-x-QPFN-1L
passively cooled diode laser on CS-mount with fast axis and slow axis collimation or fast axis collimation
optical output power: up to 90 W cw / 90 W qcw
wavelengths: 808 nm - 976 nm
JOLD-x-QPNN-1L / JOLD-x-QPFN-1L
passively cooled diode laser on CS-mount without any collimation or with fast axis collimation
optical output power: up to 300 W qcw
wavelengths: 808 nm
passively cooled diode laser with fast axis and slow axis collimation or fast axis collimation
passively cooled diode laser without any collimation or with fast axis collimation
wavelengths: 808 nm
JOLD-x-CANN-1L / JOLD-100-QANN-1L
actively cooled diode laser
optical output power: up to 80 W cw / 100 W qcw
wavelengths: 807 nm – 976 nm
Download data sheet - high power
Download data sheet - standard power
Safety and handling instructions
Contact us
顶尖科仪(中国)公司
北京:13520381780
杭州:13552346276
发表于 2009-1-22 17:15:06 | 显示全部楼层
漂流四方
你的电话是什么? 我们这有芯片
