查看: 4218|回复: 7
求助!为什么ASAP模拟结果和Zemax设计结果很不一样?
发表于 2008-12-26 11:46:21 | 显示全部楼层 |阅读模式
我用Zemax设计了一个系统,作用是把平行光聚焦到像面上,为什么用ASAP7.5模拟后发现光线根本没有被追迹?结果和设计结果也不一样?请高手指点!!!
下面是ASAP7.5的编程语句.
SYSTEM NEW
RESET
!! Define system units and wavelengths
UNITS MILLIMETERS 'Watts'
WAVELENGTH 550 NM
!! Define coatings
COATING PROPERTIES
  0 1 'TRANSMIT'
  1 0 'REFLECT'
  0 0 'ABSORB'
!! Define Media
MEDIA
  1.51452 'H-K9L'
  1.66700 'ZF2'
!! GEOMETRY DEFINITIONS BEGIN HERE
!! First lens
!! Front of the lens
SURFACE
  PLANE Z 0 ELLIPSE 5
  OBJECT 'LENS1.FRONT'
  INTERFACE COATING TRANSMIT AIR H-K9L
!! Back of the lens
SURFACE
  OPTICAL Z 3 -41.926908 ELLIPSE 5
  OBJECT 'LENS1.BACK'
!! Edge of the lens
SURFACE
  TUBE Z -1 5 5 3 5 5
  OBJECT 'LEN1.EDGE'
  INTERFACE COATING ABSORB AIR H-K9L
  BOUNDS +.3
!! Second lens
!! The front of the lens
SURFACE
  OPTICAL Z 4 20.261170 ELLIPSE 5
  OBJECT 'LENS2.FRONT'
!! The back of the lens
SURFACE
  OPTICAL Z 7 -32.430485 ELLIPSE 5
  OBJECT 'LEN2.BACK'
  INTERFACE COATING TRANSMIT H-K9L ZF2
!! The edge of the lens
SURFACE
  TUBE Z 3 5 5 7 5 5
  OBJECT 'LENS2.EDGE'
  BOUNDS +.3
!! The third lens
SURFACE
  OPTICAL Z 7 32.430485 ELLIPSE 5
  OBJECT 'LENS3.FRONT'
!! The back of yhe lens
SURFACE
  OPTICAL Z 10 124.174735 ELLIPSE 5
  OBJECT 'LENS3.BACK'
  INTERFACE COATING TRANSMIT AIR ZF2
SURFACE
  TUBE Z 5 5 5 10 5 5
  OBJECT 'LENS3.EDGE'
  INTERFACE COATING ABSORB AIR ZF2
  BOUNDS +.3
!! Detector of the system
SURFACE
  PLANE Z 40 ELLIPSE 1
  OBJECT 'DETECTOR'
  INTERFACE COATING ABSORB AIR AIR
!! SOURCE DEFINITIONS BEGIN HERE
GRID ELLIPTIC Z -10 -5 5 -5 5 101 101
  SOURCE DIRECTION 0 0 1
FLUX TOTAL 100
!! TRACE RAYS WITH OPTIONAL PLOT
WINDOW Y Z
PLOT FACETS 5 5 OVERLAY
TRACE
$VIEW
!! ANALYSIS BLOCK BEGINS HERE
CONSIDER ONLY DETECTOR
WINDOW Y X
PIXELS 101
SPOTS POSITION 'spots at best focus'
DISPLAY
  AVERAGE
  ISOMETRIC 'FOCUS'
RETURN
发表于 2008-12-26 22:04:21 | 显示全部楼层
第115行应该是 TRACE PLOT
 楼主| 发表于 2008-12-26 22:59:12 | 显示全部楼层
哦!十分感谢!!!!!!!!
发表于 2008-12-27 12:42:40 | 显示全部楼层
1)把材质名称“H-K9L”改为:“K9L”,因为它会把“-”当作减号运算符来处理。
2)你把LENS2.BACK及LENS3.FRONT的材质写错了,前者应该是K9L  AIR而不是K9L ZF2,后者应该是ZF2 AIR而不是K9L ZF2 。
3)下面是我修改后的程序,有些小问题的地方我没有写出来,你可以仔细看看。当然,有些地方可能我也是错的,也希望你能帮我指出。大家相互学习,共同进步嘛。呵呵。谢谢啊!
SYSTEM NEW
RESET
WAVELENGTH 550 NM
!! Define coatings
COATING PROPERTIES
  0 1 'TRANSMIT'
  1 0 'REFLECT'
  0 0 'ABSORB'
!! Define Media
MEDIA
  1.51452 'K9L'
  1.66700 'ZF2'
!! First lens
!! Front of the lens1
SURFACE
  PLANE Z 0 ELLIPSE 5
  INTERFACE COATING TRANSMIT AIR K9L
!! Back of the lens1
SURFACE
  OBJECT 'LENS1.BACK'
!! Edge of the lens1
SURFACE
  TUBE Z -1 5 5 3 5 5
  OBJECT 'LENS1.EDGE'
  INTERFACE COATING ABSORB AIR K9L
  BOUNDS +.3 -.2
!! Second lens
!! The front of the lens2
SURFACE
!! The back of the lens2
SURFACE
  OBJECT 'LENS2.BACK'
  INTERFACE COATING TRANSMIT K9L AIR
!! The edge of the lens2
SURFACE
  TUBE Z 3 5 5 7 5 5
  OBJECT 'LENS2.EDGE'
  BOUNDS +.3 -.2
!! The third lens
!! The front of the lens3
SURFACE
!! The back of the lens3
SURFACE
  OBJECT 'LENS3.BACK'
!! The edge of the lens3
SURFACE
  TUBE Z 5 5 5 10 5 5
  OBJECT 'LENS3.EDGE'
  BOUNDS +.3 -.2
SURFACE
  OBJECT 'DETECTOR'
FLUX TOTAL 100
WINDOW Y Z
TRACE PLOT
$VIEW
WINDOW Y X
PIXELS 101
DISPLAY
  AVERAGE
  ISOMETRIC 'FOCUS'
RETURN
 楼主| 发表于 2008-12-27 15:31:00 | 显示全部楼层
呵呵,十分感谢!!!!
不过,我的第二块和第三块之间是胶合面啊!怎么设置阿!
 楼主| 发表于 2008-12-27 16:11:41 | 显示全部楼层
呵呵,找到问题点了,是因为我不小心把曲率半径输入错误了!!呵呵,见笑了!!
发表于 2008-12-27 17:47:49 | 显示全部楼层
如果是胶合镜片的话,那么胶合面只需要建一个面就可以了,不用两个面都建
 楼主| 发表于 2008-12-28 13:29:06 | 显示全部楼层
哦。回去试一下,是什么命令啊?
