passively cooled diode laser on CS-mount with fast axis and slow axis collimation or fast axis collimation
optical output power: up to 90 W cw / 90 W qcw
wavelengths: 808 nm - 976 nm
passively cooled diode laser on CS-mount without any collimation or with fast axis collimation
optical output power: up to 300 W qcw
wavelengths: 808 nm
passively cooled diode laser with fast axis and slow axis collimation or fast axis collimation
actively cooled diode laser stack with collimation for both fast and slow-axes
optical output power per submount: up to 50 W cw
wavelengths: 807 nm – 976 nm
passively cooled fiber-coupled diode laser, with integrated TEC and pigtail with 50 µm or 100 µm fiber core diameter
optical output power: up to 4 W cw
wavelengths: 808 nm and 976 nm
optical output power: up to 7.8 W cw
passively cooled fiber-coupled diode laser, with integrated TECs and 400 µm or 600 µm fiber core diameter
optical output power: up to 45 W cw / 70 W qcw
wavelengths: 808 nm – 976 nm
passively cooled fiber-coupled diode laser, to be cooled with tap water, with 400 µm or 600 µm fiber core diameter
optical output power: up to 75 W cw / 120 W qcw
wavelengths : 808 nm – 976 nm
passively cooled fiber-coupled diode laser, to be cooled with air or tap water, with 400 µm or 600 µm fiber core diameter
optical output power: 100 W / 140 W cw
passively cooled fiber-coupled diode laser, to be cooled with tap water, with 400 µm fiber core diameter
optical output power: 250 W cw / 600 W qcw
