查看: 2251|回复: 0
zemax的一点问题
发表于 2009-3-21 10:27:32 | 显示全部楼层 |阅读模式
初学zemax有点问题请教大虾们:
1、一组透镜,它的物方主点,和像方主点在哪里给出呀?
Date : SAT MAR 21 2009
GENERAL LENS DATA:
Surfaces                :                3
Stop                    :                1
System Aperture         : Entrance Pupil Diameter = 25
Glass Catalogs          : SCHOTT
Ray Aiming              : Off
Apodization             : Uniform, factor =   0.00000E+000
Effective Focal Length  :       -34.99617 (in air at system temperature and pressure)
Effective Focal Length  :       -34.99617 (in image space)
Back Focal Length       :        56.62724
Total Track             :          1e+010
Image Space F/#         :        1.399847
Paraxial Working F/#    :        1.399847
Working F/#             :        1.159827
Image Space NA          :       0.3363691
Object Space NA         :       1.25e-009
Stop Radius             :            12.5
Paraxial Image Height   :               0
Paraxial Magnification  :               0
Entrance Pupil Diameter :              25
Entrance Pupil Position :               0
Exit Pupil Diameter     :   8.749041e-008
Exit Pupil Position     :        56.62724
Field Type              : Angle in degrees
Maximum Field           :               0
Primary Wave            :       0.4861327
Lens Units              :   Millimeters
Angular Magnification   :               0
Fields          : 1
Field Type: Angle in degrees
#        X-Value        Y-Value         Weight
1       0.000000       0.000000       1.000000
Vignetting Factors
#       VDX       VDY       VCX       VCY       VAN
1  0.000000  0.000000  0.000000  0.000000  0.000000
Wavelengths     : 3
Units: 祄
#          Value         Weight
1       0.486133       1.000000
2       0.587562       1.000000
3       0.656273       1.000000
2、比如说我选了几组透镜组成了个系统,然后我又想查询每组透镜的焦距和参数等,怎么查?
