查看: 8846|回复: 42
最新光纤激光打标机
发表于 2009-4-4 15:32:59 | 显示全部楼层 |阅读模式
英国600集团-Electrox公司 最新光纤激光打标机。
Http://electrox-china.intn.cn
Http://www.electrox.com
发表于 2009-4-4 15:38:13 | 显示全部楼层
手持的那个东东做的有点落伍,其它的因为没用过,暂时不评价
 楼主| 发表于 2009-4-4 16:07:51 | 显示全部楼层
这可不是手持的。这只是整个激光机的一个部分。
发表于 2009-4-4 16:11:36 | 显示全部楼层
价格是多少?.....................................
发表于 2009-4-4 17:04:32 | 显示全部楼层
The Raptor laser marker is powered by EF Technology, a revolutionary new platform for laser marking systems that combines the efficiency and reliability of the latest diode and fiber technologies with the utility of more conventional designs to deliver robust and versatile laser markers at an eminently affordable price. The EF Technology platform in guaranteed for 4 years.
能简单介绍一下这个EF技术吗?
 楼主| 发表于 2009-4-4 17:17:28 | 显示全部楼层
EF-ENHANCED FIBRE TECHNOLOGY
Fibre lasers have raised everyone’s expectations of laser marking systems in terms of reliability, longevity of the
consumables, laser beam quality and power efficiency.
Before the introduction of pulsed fibre lasers into marking systems, having to change a lamp every 600 hours or a
diode every 8,000 hours was considered the norm. Most lasers needed a major annual service to ensure the water
cooling system was clean, the water pumps were not worn and that the exposed optics had not been
contaminated by the normally aggressive environment they were being used in.
Fibre lasers brought with them effectively maintenance free use for greater than 17,000 hours, dispensed with the
need for water cooling and increased the total system electrical to laser efficiency ten fold from around 1% to
nearly 10%.
None of the high power, critical optics are exposed to the environment eliminating the possibility of system
degradation due to their contamination.
The beam quality produced is nearly as perfect as is theoretically possible, unlike lamp pumped lasers that for the
same power would have up to 10 times bigger spot sizes with the same optical configuration or a five times smaller
depth of focus if used at the same spot size as the fibre laser. Even compared with conventional diode pumped
lasers, fibre lasers can have over three times smaller spot sizes.
So fibre lasers have very few drawbacks and many advantages over the lasers being previously offered. However,,,,,,
发表于 2009-4-4 17:22:59 | 显示全部楼层
consumables, laser beam quality and power efficiency ...
ElectroxChina 发表于 2009-4-4 17:17
难道EF技术就是一般的光纤激光器技术吗?
 楼主| 发表于 2009-4-4 18:17:18 | 显示全部楼层
不,不是。这个可以讲是个“秘密”。简单讲,是在一定的温度下,所产生的一个“波长”。
发表于 2009-4-4 19:55:25 | 显示全部楼层
价格怎么样?看看我们能接受得了吗?
发表于 2009-4-4 21:49:40 | 显示全部楼层
E不EF之类的这些不管有多神秘,最终是要在实际中起到较大的作用,市场决定一切
 楼主| 发表于 2009-4-5 05:08:31 | 显示全部楼层
是的。有4年的保质期,且价格就20万左右,10瓦,光纤,相信市场会有的。
 楼主| 发表于 2009-4-5 05:18:12 | 显示全部楼层
不过我知道,世界上第一台C02激光机就是有Electrox公司研制和生产的。Electrox公司下属于英国600集团,而600集团是欧洲最大的机床及机械制造集团、同时也是英国上市公司。曾经获得过英国女王杯奖、。公司在全世界有325个销售、代理网点。
