查看: 2956|回复: 5
leveling off 翻译求助
发表于 2009-4-11 11:23:55 | 显示全部楼层 |阅读模式
如题,大虾们帮忙翻译下。。。
发表于 2009-4-12 10:50:41 | 显示全部楼层
1# laodisi
整个的句子是?
 楼主| 发表于 2009-4-13 09:31:55 | 显示全部楼层
整个句子是:Note the leveling off of depth per pulse with increasing fluence, which is caused by increasing plasma shielding with higher fluence.
发表于 2009-4-13 12:43:53 | 显示全部楼层
也不是很明白啊------------
发表于 2009-5-4 17:33:37 | 显示全部楼层
在高能量的情况下,由于等离子体的屏蔽作用,使得每个脉冲的产生的深度将趋于一致.
(上文应该有:随着能量的不断加大,每个脉冲产生的深度将不断加深)
发表于 2009-5-4 17:35:23 | 显示全部楼层
level off
1. To move toward stability or consistency: Prices leveled off.
2. To maneuver an aircraft into a flight attitude that is parallel to the surface of the earth after gaining or losing altitude.
