查看: 2221|回复: 0
紧急求购:自由空间隔离器
发表于 2009-5-19 23:02:41 | 显示全部楼层 |阅读模式
Demand specification;
- Operation Wavelength: 852nm
- Min. Isolation at Center Wavelength: 42dB
- Insertion Loss: <0.20dB
- Clear Aperture: >0.90mm
- Tilt Angle of Input Light: 5°
- Operating Temperature: -5~+70℃
- Storage Temperature: -40~+85℃
- Power Handling: 500mW
- Single Stage
- Size: 100mm x 100mm (Propose the largest size, when you do not fill 100mm x 100mm.)
- The diameter of a hole: 4mm
Quantity: 5pcs(for evaluation), 50pcs, 300pcs
请将产品信息发到这个邮箱地址: asowave@gmail.com
