查看: 2698|回复: 0
光栅和laser line filter 需求
发表于 2009-5-23 00:06:03 | 显示全部楼层 |阅读模式
有朋友需要以下产品,如有能提供的,请联络ifh@vip.sina.com
) Monochromator Grating ( for Oriel Instruments – 1/4m Grating Monochromator 77200)
- Grating type : ruled
- Primary Wavelength Region : 200-1200nm
- Blaze Wavelength: 350nm Peak Efficiency (%): 80 Line Density : 1200l/mm
- Reciprocal Dispersion : 3nm/mm
- Focal Length : 250mm
- Wavelength Precision :+/- 0.1nm
- Wavelength Counter Multiplier :1.0
2) Laser Line Filter
- Diameter:25.4mm
- Center Wavelength: 266+/-2nm
- FWHM : 10 +/-2nm
- Damage Threshold: 0.5J/cm2 pulsed
- X ray – Far IR blocking
3) Laser Line Filter
- Diameter:25.4mm
- Center Wavelength: 355+/-2nm
- FWHM : 10 +/-2nm
4) Laser Line Filter
- Diameter:25.4mm
- Center Wavelength: 532+/-2nm
- FWHM : 10 +/-2nm
