查看: 4614|回复: 3
[求助]快光电管的动态范围和输出幅度计算
发表于 2009-9-23 22:34:40 | 显示全部楼层 |阅读模式
最近可能需要购买快光电管,但是厂商给出的参数里面没有动态范围和输出幅度,请问根据下面已有数据能得到嘛,计算思路是怎么样的,非常感谢。
rise time: <30ps
bandwidth: >10GHz
spectral range: 300~900nm
quantum efficiency: 40%
sensity area: 0.2*0.2mm
noise eq. power: 10^(-15)
dark current: 0.1nA
material: GaAs
灵敏度:0.3 A/W
损伤阈值:5~50mW
发表于 2009-9-24 15:01:38 | 显示全部楼层
动态范围和输出范围和你的前放是有关系的,噪声可用来计算最小可探功率,1mW左右的输入光功率可作为饱和功率,算算看吧。
 楼主| 发表于 2009-9-24 23:09:17 | 显示全部楼层
2# dnke
谢谢,那就拿我发的参数来说:
NEP是3*10^(-15) watts per (hertz)1/2,用这个做为最小可探测功率,就是3fW;
饱和功率1mW;
这样的话,就有9个数量级,是不是太大了啊
另外,对光电二极管来说,前放是PN或者PIN的偏置电压那部分东西吗?
 楼主| 发表于 2009-9-28 22:33:47 | 显示全部楼层
下面是厂家的回复,我想进一步问的是,文中提到电池噪声是1E-5,这个值是如何决定动态范围的。非常感谢。
It is defined as the ratio of the maximum current amplitude (15 mA) to the dark current.
15 (mA) / 100(pA) = 150E+6, that is 150 millions.
It is a huge dynamic range. However, the limitation in this case will be limited NOT by the dynamic range of the photodiode itself, but by the noise properties of the POWER SUPPLY. Therefore, we recommend to use very low noise power supplies. The best solution is using a battery, or rechargeable battery. They have very low level of noise, probably 1E-5 or  so,. This value will determine the dynamic range.
