2009-10-4 18:34:40 | 显示全部楼层 | 阅读模式
产品名称:超连续谱光源(白光激光器)
所属类别:
超连续谱光源(白光激光器)
厂家名称:昊量光电
产品简介:     超连续谱激光器(Supercontinuum Sources)又称超连续激光器、超连续光源、白光激光器。其光谱可覆盖320~2400nm的广阔范围。
特点:
光谱覆盖 320 ~ 2400nm
单模输出
亚纳秒脉冲
主要应用:
光谱学 (Spectroscopy)
光学相干层析技术(Optical Coherence Tomography, OCT)
共聚焦显微分析(Confocal Microscopy)
流式细胞仪(Flow cytometry)
激光雷达(Light Detection and Ranging,LIDAR)
光学器件检测(Optical component testing)
  1, 标准超连续光源
SM-20
SM-8
Spectral bandwidth
400 nm –> 2400 nm
400 nm –> 2400 nm
Spatial profile
Singlemode (LP01 mode)
Total average power
> 60 mW
> 20 mW
Repetition rate
20 kHz
8 kHz
Pulse width
< 1 ns
< 1 ns
Spectrum
See complete datasheet
2, 覆盖紫外范围的超连续光源
UV-8
UV-20
Spectral bandwidth
320 nm –> 1750 nm**
320 nm –> 1750 nm**
Spatial profile
Singlemode (LP11 mode in the visible range)
Total average power
> 15 mW
> 65 mW
Repetition rate
8 kHz
20 kHz
Pulse width
< 1 ns
< 1 ns
Spectrum
3, 带触发功能的超连续光源
STP-4
STM-4
Spectral bandwidth
370 nm –> 1750 nm*
400 nm –> 1750 nm*
Spatial profile
Singlemode (LP01 mode in the visible range)
Total average power
< 10 mW
< 12 mW
Repetition rate
From 10 Hz to 4 kHz
From 10 Hz to 4 kHz
Pulse width
< 1 ns
< 1 ns
Timing jitter
< 2 &micro;s
< 2 &micro;s
Spectrum
