德国Linos超精密五维调整架,分辨率可达nm级别,感兴趣的话,可以与我们联系,021-62562268 蔡 www.zugophotonics.com
5-Axis Positioner I5000
The five-axis positioner I5000 is easy to use, very touch insensitive and hysteresis-free and lets you reach the desired position quickly. Even fibers with a core diameter of 1 - 2 µm can be easily aligned towards each other. With the patented and ergonomic inline-design, all micrometer screws are easily accessible on one side.
Innovation
The five-axis positioner I5000 is equipped with the patented Ratio DriveTM, while other positioners are driven directly. The Ratio DriveTM transmission enables a resolution of 1 nm. The rotation and tilt axes use similar mechanical advantages to convert the linear motion of the micrometer screws into very precise rotation motions. The backlash is at maximum 20 nm. The I5000 is insensitive to vibrations and temperature fluctuations.
Conventional multi-axis positioners usually consist of individual components for the respective motion. The stiffness of the entire structure is lost and the force when touching the adjustment screws is transmitted up to the positioner's output. This results in the known cycle of adjusting, letting go and waiting for the user.
The I5000 consists of two combined basic elements. The Z-adjuster is a separate positioner, while all other axes share the same casing. With this joint stable frame, the force applied by the user is transmitted to the base plate but not to the output of the positioner, which makes positioning very easy. An internal shock absorber eliminates the typical resonance effects of a flexure positioner.
Small space requirement
All operating elements aligned on one side
Patented 25x Ratio DriveTM system offers high resolution
Absorbing outer casing ensures low vibration and touch sensitivity
Patented double solid body joint provides friction-free and straight-line adjustment
Travel: 12.7 mm, total 12.7 mm (z-focus) / 0.5 mm, total 2.5 mm (y-vertical and x-lateral) / 3 degrees, total 3 degrees (yaw and pitch)
Setability micrometer resolution: 0.25 µm, 25 µm division (z axes) / 10 nm, 1 µm (25x-Ratio Drive - y and x-axes) / 0.2 arc sec, 30 arc sec division (roll and yaw axes)
Flexure type: double (z, roll and yaw axes), single (y and x axes)
Arc error: none (z, roll and yaw axes), max.30 µm (y and x axes, in z only)
10 N maximum load
Aluminum material, RoHs conform
Mounting height 131.8 mm (base to top of mounting plate)
Concurrent rotation center 12.7 mm (out from end of mounting plate)
Dimensions L x W x H (excluding micrometer) 114.3 x 44.5 x 131.8 mm
1.5 kg weight |
