楼主 |
发表于 2003-3-20 19:59:00
显示全部楼层
ZEMAX 问题集??
[这个贴子最后由zfw0080在 2003/03/20 12:03pm 第 1 次编辑]
我自己的结果是:
GENERAL LENS DATA:
Surfaces : 6
Stop : 5
System Aperture : Entrance Pupil Diameter = 2
Effective Focal Length : 4.306656 (in air at system temperature and pressure)
Effective Focal Length : 4.306656 (in image space)
Back Focal Length : 4.657714
Total Track : 10.96519
Image Space F/# : 2.153328
Paraxial Working F/# : 2.153328
Working F/# : 2.040261
Image Space NA : 0.2261813
Object Space NA : 1e-010
Stop Radius : 1.081515
Paraxial Image Height : 2.5877
Paraxial Magnification : 0
Entrance Pupil Diameter : 2
Entrance Pupil Position : 3.900807
Exit Pupil Diameter : 2.16303
Exit Pupil Position : -4.671219
Field Type : Angle in degrees
Maximum Field : 31
Primary Wave : 0.5875618
Lens Units : Millimeters
Angular Magnification : 0.9246287
Distortion 2 %
Resolution 90lp/mm@full field时MTF大于0.1
希望各位给与指点。
