查看: 1815|回复: 2
reflecting gratings
发表于 2009-12-18 01:12:43 | 显示全部楼层 |阅读模式
Hello, can someone tell me how to model a reflecting grating? If you choose surface type as diffraction grating, a transmission grating will appear.
 楼主| 发表于 2009-12-20 05:13:36 | 显示全部楼层
Ok. I have figured out.
In the sequential mode, both reflection and  transmission grating is represented by the surface type of "diffraction grating". The position of next surface will tell the computer that the grating is a reflection or a transmission. If the thickness of the grating is positive (+), the next surface will be in the right to the grating. The grating will be a transmission type. If the thickness of the grating is negative (-), the next surface will be in the left to the grating. The grating will be a reflection type.
发表于 2009-12-20 12:23:11 | 显示全部楼层
Please speak in Chinese!
