查看: 2637|回复: 2
CODE V 9.5 surface type grating
发表于 2010-1-10 01:07:21 | 显示全部楼层 |阅读模式
那位大侠能指点一下为何我的 code V 9.5 surface type 里边 没有grating
非常感谢!
发表于 2010-1-10 10:45:50 | 显示全部楼层
right-click surface type, choose  Surface properties>diffractive properties>linear grating
 楼主| 发表于 2010-1-10 15:51:25 | 显示全部楼层
回复 2# hutuwa
    Thanks for hutuwa, it works perfectly in your way. Though the surface type used is still an infinity radius sphere.
Thank you very much!
