2003-11-14 19:51:00 | 显示全部楼层 | 阅读模式
say if I have Michelson interferometer, how to analysis the output interferogram?
3285查看5回复
2003-11-14 20:54:00
any example to analysis interferometer in zemax
actually, be little more general, is there any example on Multi-Configureation Editor?
Thanks in advance
2003-11-14 22:34:00
干涉图的处理需要专门的处理软件,如intelliwave。
用multi-configuration设计干涉仪,ZEMAX中有相应的例子,可以直接打开看。
2003-11-16 18:52:00
I saw one example in non-sequential folder, called beam splitter.zmx
is non-sequential lens same as multi-configuration?
And I need to change that beam splitter and using two half-penta prism, how do I modify which surface of my prism has 50/50 Reflect/Transmission rate?
2003-11-19 21:00:00
不一样。
ZEMAX里有干涉仪的例子,多重结构与non-sequential是不同的
2003-12-15 07:01:00
There is a lot of examples in zemax for modeling of interferometer,
They all use MC editor,typically 2 configurations,one is the refrence optical path,the other is the measure path,see?
if you have any question about the modeling of interferometer,drop
me a mail at sanyuesan@sina.com
